Sn95 overheating
Old Jun 23, 2018 | 06:21 AM
Jacob Parsons's Avatar
Angry Sn95 overheating
alright so if I let my 95 get idle it climbs to the l in the normal on the coolant temp gauge when I blurp the gas it jumps back down also gets cool while driving and if I’m driving it won’t get hot unless I’m stopped somewhere. Just put a 180 thermostat in also a new water pump. I checked flow in the radiator and in the block while I was doing the water pump. I also put a new radiator cap on. The car doesn’t leak any coolant nor is it mixing with the oil. I am also not getting any white smoke out of the tailpipe. the only thing I can think of is maybe air in the system still or the heater core is clogged even tho my heat works and gets hot. Also having the a/c on doesn’t make the problem worse and the car has never overheated.
Any any help or pointers would be appreciated thanks
Old Jun 27, 2018 | 06:03 PM
slow.stang's Avatar
Sounds like primary fan is bad and other fan kicks on when you're running AC. Unless I misinterpreted something.
Old Jun 27, 2018 | 06:14 PM
This car on has an electric fan
Old Jun 27, 2018 | 06:19 PM
slow.stang's Avatar
Is it coming on when the AC isn't on?
Dez
19
Mar 1, 2011 03:33 PM
2010MustangGT
Oct 12, 2010 02:26 PM
TheRealOne
Jun 21, 2010 11:07 PM
Stix66
Mar 26, 2008 09:14 PM
KrisHorton
17
Jan 14, 2008 08:37 PM
