Sn95 overheating
alright so if I let my 95 get idle it climbs to the l in the normal on the coolant temp gauge when I blurp the gas it jumps back down also gets cool while driving and if I’m driving it won’t get hot unless I’m stopped somewhere. Just put a 180 thermostat in also a new water pump. I checked flow in the radiator and in the block while I was doing the water pump. I also put a new radiator cap on. The car doesn’t leak any coolant nor is it mixing with the oil. I am also not getting any white smoke out of the tailpipe. the only thing I can think of is maybe air in the system still or the heater core is clogged even tho my heat works and gets hot. Also having the a/c on doesn’t make the problem worse and the car has never overheated. Any any help or pointers would be appreciated thanks |
Originally Posted by Jacob Parsons
(Post 7031491)
This car on has an electric fan
(Post 7031718)
