Replacing Mirror Help
Old Aug 7, 2007 | 09:26 AM
Miserable's Avatar
Had a truck driver help me lighten the car a bit the other night by taking off my driver’s side mirror. I want to replace this myself rather then pay a dealership to do something that seems pretty simple.
It looks like I just need to do the following:
Remove tweeter cover
Unscrew tweeter from door and unhook the connector
Unbolt the 3 bolts holding the pieces left of the mirror assembly
Remove the window controls panel
Unhook the mirror wire from the connector there
Plug in the new mirror wire
Bolt the new mirror on
Put everything back together
Does anyone know if I missed anything? I saw people saying that you need to remove the entire door panel but it looks like I don’t have to do that if the connector for the mirror wire is right behind the window controls.
Old Aug 8, 2007 | 03:25 PM
jgsmuzzy's Avatar
Sounds good to me. Even if it turns out that you need to remove the door panel, it is no biggy, just make sure you do not break the clips.
Old Aug 8, 2007 | 03:42 PM
Knight's Avatar
Needs to be more Astony
Nah I had to replace the mirror on my 99 at one point and you do not have to take off the door panel.
everything you stated was the exact steps.
Old Aug 9, 2007 | 01:59 PM
Miserable's Avatar
Cool, thanks guys.
Old Aug 9, 2007 | 03:33 PM
Knight's Avatar
Oh one more thing..i dunno if you did it yet or not. but If i remember correctly you do not ahve to take off the window controls on the door. I beleive the connector was up near the mirror assembly so it can be disconnected and reconnected right from there.
I could be worng but i honestly don't remember having to remove those controls.
Old Aug 9, 2007 | 05:10 PM
Miserable's Avatar
you're correct, I can access the wire from the tweeter but I couldn't get my hand in there far enough to get to the wire. It's pretty easy to get to with the window control panel out though.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
