O/D problem
Old Sep 8, 2013 | 09:10 AM
JFlakes's Avatar
O/D problem
I have a 2000 V6,, I'm having problems with the o/d. I can push the o/d button and nothing happens, the light in the dash will not even come. Checked the fuse and made sure it was plugged up. Could I be missing something?
Old Sep 8, 2013 | 09:59 AM
shurtual86's Avatar
Have you recently removed the shifter? The wires going to the o/d button or tranny could be cut or the bulb in the gauge cluster could be burnt out.
Old Sep 8, 2013 | 11:02 AM
AzPete's Avatar
Does the tranny shift normally....including od? Need to sort out kf it is a tranny issue or an electronic/wiring issue.
Old Sep 8, 2013 | 11:56 AM
JFlakes's Avatar
I did remove the cover when I seem it wasn't shifting into o/d with the button. The transmission does shift normal,, just doesn't shift into o/d when using the button.
Old Sep 8, 2013 | 12:01 PM
JFlakes's Avatar
I do need to check the bulb though,, I can do that when I replace the plastic over the gauges. It just seems the button doesn't work to engage the o/d. The guy I bought it from let the car sit up for 6 months, but I've been driving it for almost a year and have not replaced the trans filter. And the o/d wasn't working when I bought the car.
Old Sep 8, 2013 | 06:43 PM
AzPete's Avatar
If the od light is off..as when you first start the car and leave the od button alone..the car should shift into od automatically. Does the car NEVER shift into od?
Old Sep 8, 2013 | 08:01 PM
JFlakes's Avatar
Nope.
Old Sep 9, 2013 | 08:41 AM
AzPete's Avatar
Could be a transmission issue......might have a shop check it out.
Rando
Aug 25, 2021 11:12 AM
Mpaps
Oct 11, 2017 08:06 PM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
