Loose Drive shaft
Old Feb 18, 2008 | 06:58 PM
DrunkenDragon713's Avatar
Loose Drive shaft
Got my 2000 GT inspected today and the mechanic said that my drive shaft is loose. Is it the bearings? Do I need a new one?
I'm trying to sell this car asap and this lost me a sale...
Old Feb 18, 2008 | 07:10 PM
bluethunderhorse's Avatar
most likely its the universal joints
Old Feb 18, 2008 | 07:12 PM
karman's Avatar
Loose where?
Rotationally, attachment, etc.
Old Feb 19, 2008 | 02:30 AM
They didn't say. ALl they did was write it on a sheet of paper and handed it to the guy.
Old Feb 19, 2008 | 12:47 PM
cntchds's Avatar
If I were you I would get under there and check out what's goin on.
Old Feb 20, 2008 | 04:40 AM
Called them yesterday before work, they said the joint is loose and either needs to be tightened or replaced. So which one is it? Can it be just tightened like a screw?
Friday when I wake up I'll be jacking up the car and checking things out.
Old Feb 20, 2008 | 06:03 PM
the only thing that can come loose is the bolts that hold the driveshaft to the pinion flange most likely one or both of the universal joints are bad
Old Feb 20, 2008 | 06:12 PM
karman's Avatar
It probably just needs new u-joints.
Cheap fix.
What kind of a dummy would pass up a car if the only thing wrong with it was worn u-joints?
I wonder if whatever car he buys, the mechanic gives an okay and then it ends up costing him $2000 to fix something the guy couldn't see.
Old Feb 21, 2008 | 04:29 AM
The mechanic also told him that a transmission mount costs $1500-$2000 to replace. $100 in parts, $1400-$1900 in labor for about 2 hours of work... sounds fair to me!!!
Old Feb 21, 2008 | 04:41 AM
Also, is http://store.summitracing.com/partde...5&autoview=sku
this the right part? Doesn't say anything about it being for the drive shaft though...
Or would this work?
http://www.autozone.com/selectedZip,.../selectZip.htm
Seeing how it's such a cheap part, I might as well just get it locally and save on the shipping.
Old Feb 21, 2008 | 07:00 AM
either one will work
FromZto5
75
Oct 5, 2015 02:27 PM
Evil_Capri
Sep 11, 2015 08:39 AM
oldnjguy
Sep 10, 2015 02:39 PM
Road_Runner
Sep 10, 2015 01:14 PM
Road_Runner
Sep 10, 2015 11:28 AM
