Horn Alarm Going Off ( Shop Manual pdf's For Alarm & Door Lock System}
Old Jun 24, 2024 | 02:02 PM
colorado cobra's Avatar
Just bought a 1996 Cobra and after pressing the door lock button on the key chain, the horn sounds off in 30 seconds. I tried replacing the theft alarm module in the trunk with no change, and the door ajar switches seem to be functioning normally. Does anyone have any other ideas?
Changed Title To Make Easier For Others To Search For!
KC ADMIN 06/24/2024
Old Jun 24, 2024 | 03:52 PM
05stangkc's Avatar
@colorado cobra
Post a Pic of The Transmitter Fob Please!
Sometimes Ford Would use a Hybrid Style Transmitter Which Would Integrate FORD FACTORY ALARM with FORD DEALER INSTALLED Alarm. That is a Different Can o Worms. A Quick Visual Will tell Me Which One it Is!
Welcome!
Kc
Here are Some Factory Shop Manual Pdf's on The FACTORY Alarm System To Help! Let Me Know If You Need Any Other Sections as The Pdf's Do Reference The Door Lock System as Well. I Went Ahead & Added So Here They Are As Well!
Might Want To Print Out ! Gonna Need Some Paper!
In Order!
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 24, 2024 | 04:02 PM
m05fastbackGT's Avatar
Does the horn sound off only when pressing the door lock button on the keyfob or does it also sound off when pressing the door lock manually on the door itself? Otherwise, if it's only when using the keyfob, consider replacing the battery with a new one and see if that fixes the problem, if it doesn't, then you'll more than likely require replacement of the keyfob...
Old Jun 24, 2024 | 04:08 PM
05stangkc's Avatar
Always Good To Have a Fresh Battery in The Transmitter!
KC
Old Jun 24, 2024 | 04:18 PM
It does indeed!
Old Jun 24, 2024 | 06:07 PM
I tried the 2nd keyfob and the same thing happened. When manually locking the doors, the alarm does not sound.
Old Jun 25, 2024 | 01:21 PM
Then you need to follow up with Kevin (KC) My guess is the keyfobs more than likely are not the original/factory keyfobs for your "96" Cobra and would therefore require reprogramming thru your local Ford dealership in order to function properly...
svetlana92
Jun 15, 2017 05:47 PM
Xanadu
Mar 15, 2012 06:11 PM
Reminisce
Sep 30, 2008 12:13 PM
Axslynger
Jan 31, 2007 10:58 AM
