HELP - Odometer Repaired/ Spinning Too Fast
Old Nov 28, 2018 | 06:24 AM
Notivation's Avatar
Hey guys, I finished repairing my odometer on my 1998 Mustang GT just like Chrisfix did
I took it on it's first run to work, 4.2 miles away. However, when I got home, it showed 10 miles. So I drove 8.4 miles, but it's showing 10 miles? The only thing I can think of is I changed the three layered gear, but not the worm gear. What did I do wrong and how can I fix that? Everything is stock besides a new radio and odometer gear.
Old Nov 28, 2018 | 11:18 PM
houtex's Avatar
If you didn't replace the worm gear, it's likely you've changed the gear ratio. Gears like this come as a set. It's very possible they changed the Teeth Per Inch on the regular gear to reduce stress, and adjusted the angle of the worm gear to compensate. The other end of the toothed gear they wouldn't have changed.
That's my theory. Replace the worm gear to match the set, I bet it solves itself.
Oh, and welcome aboard!
Old Jan 2, 2019 | 05:01 PM
figueroa's Avatar
fix the cable or look at the cable probably broken
cobramatt
'10-14 SMS SuperCars Mustangs
May 19, 2014 03:41 PM
Deric
Jul 17, 2008 09:42 AM
BlueBossS197
1994-2004 V-8
May 25, 2008 05:16 PM
Dougxox
Sep 17, 2007 03:25 PM
EleanorsMine
05-09 Exterior Modifications
Dec 31, 2004 03:29 PM
