HELP - Odometer Repaired/ Spinning Too Fast
Hey guys, I finished repairing my odometer on my 1998 Mustang GT just like Chrisfix did
If you didn't replace the worm gear, it's likely you've changed the gear ratio. Gears like this come as a set. It's very possible they changed the Teeth Per Inch on the regular gear to reduce stress, and adjusted the angle of the worm gear to compensate. The other end of the toothed gear they wouldn't have changed.
That's my theory. Replace the worm gear to match the set, I bet it solves itself. :nice: Oh, and welcome aboard! :wave: |
fix the cable or look at the cable probably broken
