Battery Slowly draining
Old Apr 21, 2006 | 03:51 PM
98stang's Avatar
I have a 1998 GT that has a very slow electrical drain that will run the battery down in about 7 days if the car is not started.
The battery has been replaced...still happens.
If I pull fuse #8 out, the car can sit for weeks without any drain.
fuse #8 powers:
- Courtesy Lamps
- Radio
- Power Mirrors
- Remote Keyless Entry
I physically removed the radio because it is aftermarket and I thought that might fix the problem...but no.
Any brilliant ideas? [img]style_emoticons/<#EMO_DIR#>/headscratch.gif[/img]
Old Apr 21, 2006 | 06:55 PM
tdischer's Avatar
yOU HAVE A SHORT SOMEWHERE.
I would start witht he power mirrors. A Motor that is shorting internally can draw power. See if either motor is warm or hot this may be a tell tail sign.
next check the wire harnesses for the other system for any frays or tears in the outer jacket.
Got luck !!
Hope this helps. [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old Apr 21, 2006 | 07:01 PM
98stang's Avatar
Thanks, I'll play around with it and see.
Old Apr 23, 2006 | 04:03 AM
jgsmuzzy's Avatar
I think the keyless entry takes a voltage at all times. Is your battery old? could explain how even a tiny drain will affect the cars starting.
Uofmrampage
Aug 2, 2022 02:55 PM
lakersfreak
Jun 13, 2022 12:29 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
PonyMuscletang13
Sep 24, 2015 01:40 PM
