4r70w issue
4r70w issue
1998 GT Auto with transmission issue. Reverse is good, OD is good, 3rd is good. Problem is slipping in 1-2. All issues started when down shifting from 3 to 2 on acceleration. Would rev high before shift. Changed fluid and filter and seemed fine for 2 to 3 days. Now this. Ideas?
The Analog Admin!
Received 2,992 Likes
Factory Shop Manual PDF'S
@Cduke
Hello,
Welcome To Tms.
I Have Enclosed What I Think are The Relevant Shop Manual Pdf's For You! Have You Checked For Codes! If Not Maybe a Good Idea.
If You Don't Have a Reader Many Auto Parts Stores Will Check For Free!
Oh and on A Side Note Unless You Have a Drain Plug On the Torque Converter When You Do A Fluid & Filter Change There is Still Quite a Bit of Old Dirty Fluid Left in the System So You Might want to Take a Good Look At the Fluid and See if it Looks Dirty Again Already. The Additive Will Help if The Fluid You Changed Was Really Dirty in the First Place.
Take A Good Look at The Bg Info as It May Help as Well
As Far as Additives Which May Help I Used & Sold Bg Products While Work At Ford Dealer's For 3+ Decades. Surely Would Not Hurt!
https://www.bgprod.com/catalog/category/transmission/
Hopefully Some of this Info Will Help!
Mgb,
Kc
Hello,
Welcome To Tms.
Mgb,
Kc
@Cduke
Hello,
Welcome To Tms.
https://www.amazon.com/BG-ATC-Plus/dp/B00D7FSFTS
Mgb,
Kc
Hello,
Welcome To Tms.
Mgb,
Kc
The Analog Admin!
Best of Luck on the Repair!
Please if Any Others Have Some Thoughts Chime In!
Let Us Know When You Resolve so Others Can Benefit!
I'm Cleaning Up All The Forums to Make it Easier To Find Past Solutions & More Interesting on Things. Actually Working on SN-95'S Right Now!
I Hope to See it Active Again!
Mgb,
KC
NOTE
For Those Viewing See The New By Model Curated Content Sub Sections. View Cool Articles & Pics By Your Model Of Interest!
Hundreds of these Articles Were Buried Deep in General Chat with no Particular Theme in the Past.
Those With No Set or Varied Models are in Various Forum.
https://themustangsource.com/forums/f870/
