2004 GT fuel injectors
Old Apr 19, 2010 | 09:15 AM
SVTCobraR315's Avatar
I was planning on going for a roots type supercharger in the future... What kind of fuel injectors would be good for that application? I pretty much have an idea of what I want to do, except I'm not to sure on the fuel system and ignition system. What do you guys recommend?
Old Apr 22, 2010 | 07:28 AM
Scothew's Avatar
Stubborn Bear
TMS Staff
totally depends on the application. Most s/c are goign to require a 36# or higher, but as long as you arent going crazy, I think alot of folks just used the 2003/2004 cobra injectors (which were 36 if I am remembering right)
Old Apr 30, 2010 | 07:51 AM
JScottGT's Avatar
Most tuners will not touch your car unless it has 42#/hr injectors (green tops). While the 39's from a cobra will work just fine, the 42's are easier for them to tune with and give a little head room so you are not running any more than 80% duty cycle. With that large of an injector, you will also have to upgrade to a high-flow fuel pump like the SVT focus pump.
Old May 9, 2010 | 02:01 PM
boduke0220's Avatar
42's are what comes with the Kennebells
Old Jun 17, 2010 | 11:30 AM
whats a stock 2004 GT fuel injector? like 20 something lbs?
Old Jun 17, 2010 | 12:14 PM
SuperSugeKnight's Avatar
Stock are 24lbs I believe. They upped them from 19lbs from the previous years.
I'm running 42lbs SVT Lightning injectors on my Vortech supercharged '04 GT.
Old Jun 18, 2010 | 06:24 AM
JScottGT's Avatar
The stock 2004 injector is a pink top 21#/hr injector. 24's are blue tops.
NC14GT
Feb 20, 2023 09:42 AM
Sep 16, 2015 06:44 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
