2004 GT fuel injectors
I was planning on going for a roots type supercharger in the future... What kind of fuel injectors would be good for that application? I pretty much have an idea of what I want to do, except I'm not to sure on the fuel system and ignition system. What do you guys recommend?
Stubborn Bear
TMS Staff
TMS Staff
totally depends on the application. Most s/c are goign to require a 36# or higher, but as long as you arent going crazy, I think alot of folks just used the 2003/2004 cobra injectors (which were 36 if I am remembering right)
Most tuners will not touch your car unless it has 42#/hr injectors (green tops). While the 39's from a cobra will work just fine, the 42's are easier for them to tune with and give a little head room so you are not running any more than 80% duty cycle. With that large of an injector, you will also have to upgrade to a high-flow fuel pump like the SVT focus pump.
Stock are 24lbs I believe. They upped them from 19lbs from the previous years.
I'm running 42lbs SVT Lightning injectors on my Vortech supercharged '04 GT.
9/16/15 06:44 PM
