2001 Bullitt #3006
Old 11/6/13, 09:37 PM
  #1261
Location: That town you drive through to get to Myrtle Beach
It drops before redline for sure. I'd go maybe 500-750 under.
Old 11/6/13, 09:45 PM
  #1262
future9er24's Avatar
Good to know. I wonder how much (if at all) my 91 tune/CAI combo affect that figure..
Old 11/7/13, 07:27 AM
  #1263
conv_stang's Avatar
Not much, the factory air box isn't that much of a restriction. And the tune will add a little to the top end but not much. The 2V just doesn't breathe enough to spin that high with the stock plastic intake and cams
Old 11/7/13, 08:42 AM
  #1264
what plastic intake :P
Old 11/7/13, 08:48 AM
  #1265
conv_stang's Avatar
Lol...it's too early on this side of the country
Had an 04Gt lol forgot you had a Bullitt lol
Old 11/7/13, 08:55 AM
  #1266
lol no worries
does your comment still apply though? because I found it super strange that I had more wheelspin on the 1-2 shift than on the launch
either way, thanks for the info
Old 11/7/13, 11:08 AM
  #1267
conv_stang's Avatar
lol no worries does your comment still apply though? because I found it super strange that I had more wheelspin on the 1-2 shift than on the launch either way, thanks for the info
Starting line has more chemical down than the rest of the track making it stickier. And depending on where you launch. The car makes more power and torque at 6000 than 2500
Old 11/7/13, 11:10 AM
  #1268
hadnt thought about the chemicals...
I see what you're saying, its just such a weird sensation lol.
Old 11/7/13, 12:19 PM
  #1269
conv_stang's Avatar
hadnt thought about the chemicals... I see what you're saying, its just such a weird sensation lol.
Yep...it takes a master to get good times in a manual car on street tires. And I'm not, so I goto my good old Mickey's loll
Old 11/8/13, 01:25 AM
  #1270
4 hours of traffic and $200 yielded some Mickey Thompson drag radials on Mach 1 wheels today
This upcoming wednesday is the last day for Infineon's wednesday night drags this season, so hopefully i can finally break this darn barrier lol
As a side note, this guy was at least a Gary tier of baller. 09 gt500, F150 FX4 and lightning, 03 GT vert, blown 01 cobra and a GTI.
Also if Jill is reading, washed and waxed the bullitt today. pics tomorrow
Old 11/8/13, 02:14 AM
  #1271
4 hours of traffic and $200 yielded some Mickey Thompson drag radials on Mach 1 wheels today This upcoming wednesday is the last day for Infineon's wednesday night drags this season, so hopefully i can finally break this darn barrier lol As a side note, this guy was at least a Gary tier of baller. 09 gt500, F150 FX4 and lightning, 03 GT vert, blown 01 cobra and a GTI. Also if Jill is reading, washed and waxed the bullitt today. pics tomorrow
Want to let me borrow them if I come out next week?
Old 11/8/13, 04:57 AM
  #1272
Evil_Capri's Avatar
Alright! Don't go too low with air pressure (I assume 275/40/17) as they can spin on the rim when performing a burnout in the box. Which isn't a huge deal, but something to be aware off.
M/Ts are what I had. Good drag radial!
Old 11/8/13, 07:54 AM
  #1273
conv_stang's Avatar
Originally Posted by Evil_Capri
Alright! Don't go too low with air pressure (I assume 275/40/17) as they can spin on the rim when performing a burnout in the box. Which isn't a huge deal, but something to be aware off. M/Ts are what I had. Good drag radial!
Best street radial out. I start at 20 PSI and go down a little from there. But never been below 18. And you don't have to do a big funny car burnout just wasting rubber. Once you see smoke you should be good
Old 11/8/13, 09:42 AM
  #1274
good to know! I havent been doing burnouts there since I assumed it was a waste on street tires.
I cannot wait to try these suckas out
Old 11/8/13, 10:09 AM
  #1275
good to know! I havent been doing burnouts there since I assumed it was a waste on street tires. I cannot wait to try these suckas out
I think doing burnouts on the street tires ruined my launches - the tires were covered with the chemical stuff they treat the track with, and became super slick. I could launch harder on the street!
Old 11/8/13, 10:16 AM
  #1276
wouldn't whatever they coat the track with make it stickier?
Also did you go in the waterbox? because my worst times a few years ago were always when i did that
Old 11/8/13, 12:23 PM
  #1277
conv_stang's Avatar
wouldn't whatever they coat the track with make it stickier? Also did you go in the waterbox? because my worst times a few years ago were always when i did that
Too much heat in some street tires make them greasy. Street tires I pull around and back into the box, same with running drag radials if I have regular street tires on the front so I don't track water to start line.
One street tires if do a quick burn out just to clean them off. If I'm running skinnies on the front I drive into the box.
Old 11/8/13, 01:56 PM
  #1278
nice day for an oil change. also got a chance to use the Opel mechanics shirt i bought at a tractor show in protein, Ireland. i dont feel bad wiping used oil on a GM shirt
also a pic of the MTs. the mach 1 wheels don't even have any noticeable curb rash or anything.
Old 11/9/13, 12:02 AM
  #1279
Too much heat in some street tires make them greasy. Street tires I pull around and back into the box, same with running drag radials if I have regular street tires on the front so I don't track water to start line. One street tires if do a quick burn out just to clean them off. If I'm running skinnies on the front I drive into the box.
This. And this is what I did, with a short burnout, still couldn't hook. I definitely launched with too high of an RPM though.
Old 11/9/13, 02:39 PM
  #1280
conv_stang's Avatar
Street tires are hard...you have to have enough revs and slip the clutch just right. I'll make a few passes on stock tires as a baseline and then goto drag radials.
Quick Reply: 2001 Bullitt #3006
