Will this work?
Will this work?
2006 Mustang GT, Shaker 500.
Will this work out of the box?
http://motors.shop.ebay.com/i.html?B...E:B:SS:US:1150
It says OEM for 05-09 Mustangs, but it also say's it will not fit a premium sound system. Is a Shaker 500 premium sound? I thought all Mustang GT's came with at least the Shaker 500.
I looked at the description and thought it was OEM, but it's definitely not the stock nav unit for the Mustang. https://themustangsource.com/f692/20...e-f150-495145/ There's a pic in there showing what it should look like. Premium sound system is referring to the Shaker 1000. It has no way to turn the Shaker on/off.
I couldn't find where they claim it is OEM. It is definitely NOT OEM, though.
I am confused by their statement that cars with nav already having a different wiring harness. I had the Shaker 500 and switched to the OEM nav and it was plug and play.
It says "OEM look" and "OEM fitment". I just hadn't read it very carefully. I don't understand why it wouldn't fit a car that already has nav either. I should have the same plugs or none of them would work together.
I installed that unit a few months back. Just be aware that you may have to re-pin the adapter that comes with it and may need to provide power to illuminate it. I did. Then again, I only had the stock radio installed, so the adapter may come set up for the Shaker. You can use the link to the F150 forum in the above mentioned thread to get the pinouts if it needs to be re-pinned.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Sep 24, 2015 08:15 PM
