Want to use factory switches with heated seats
Old Nov 10, 2006 | 03:54 PM
jim010's Avatar
I haven't had much feedback on this
I want to use the factory heated seat switches from the 07 (part number 7R3Z-19980-B). The switches are 1 stage only, apparently.
I need to know if there are heated seat coil and harness that would be compatible with these switches.
If not, and I need to get all the Ford parts to do this, where would the harness have to plug into?
Cheers
Old Nov 12, 2006 | 03:22 PM
jim010's Avatar
Umm...
Can anybody help me with this? I basically would like to know where to plug in the heated seat harness (factory or aftermarket).
Old Nov 17, 2006 | 04:37 PM
Northwest GT's Avatar
Might be worth checking with KC at Clevparts@aol.com. Or, give him a call.
Old Nov 18, 2006 | 08:49 PM
jim010's Avatar
I bought the console with the factory switches. They are located where the blankout buttons between the a/c , air circulation and rear defrost buttons are, below the climate control ***** are. You can't just buy the buttons, you need to buy the whole panel with the a/c controls.
By the way, the ***** on the new panel have more resistance than the 05/06 ones do, and so don't have that cheap feel that I hated.
Its pricey, but I want the factory look. I found a place that said they should be able to hook up thier aftermarket kit to these buttons. Will let you know.
Old Nov 22, 2006 | 05:06 PM
mrkabc's Avatar
Jim... if you don't mind my asking... what did that switch cluster run you?
Old Nov 23, 2006 | 09:02 AM
jim010's Avatar
I di not get the wirng harness. The assembly cost me $258, but it comes with the entire climate control. The ***** ae a higher quality feel than the old ones. Pretty pricey to gett that factory look, but it is what I want. I'll let you know when I get it delivered and installed.
Cheers
Old Nov 24, 2006 | 01:21 PM
sodaman's Avatar
Well from what I remember the 07 you cant switch out the buttons for aftermarket, there like glued or something. So if you want the look of bullit buttons this mod wont let you. I love the idea tho putting the factory switches into play. good luck please post some details when your done. thanks
Old Dec 6, 2006 | 08:53 AM
jim010's Avatar
You can switch out the buttons, but you need to replace the entire cluster, not the individual buttons.
I just recieved the cluster in the mail. Warning! Don't use UPS if you are shipping into Canada. They made me pay $70 in brokerage fees!!
Yes, it still hurts when I sit.
Old Dec 6, 2006 | 07:11 PM
Deric's Avatar
Well at least it will be warm
Old Dec 8, 2006 | 09:31 AM
jim010's Avatar
OK, question...
Which wires can I tap from the climate control module to send power to the heated seats? I don't know which pins are for what.
Old Jan 5, 2007 | 08:15 PM
jim010's Avatar
OK,
Took a while, but I figured it all out.
For those wanting hte stock dash switches, here's how it works.
First, you need the climate control module from a 2007.
Driver's:
12v power through a 25amp fuse to a relay (pin 30 and 86). From the back of the climate control module, attach a wire to pin 12 to the relay (pin 85). Then attach a wire from pin 87 to the heated seat.
Passenger:
12v power through same 25amp fuse to a different relay (pin 30 and 86). From the back of the climate control module, attach a wire to pin 13 to the relay (pin 85). Then attach a wire from pin 87 to the heated seat.
Hope this helps.
Cheers
Old Jan 5, 2007 | 09:42 PM
RedDragon777's Avatar
the thing that i do not like is that you can not use MGW billet a/c ***** on the 2007 a/c turn switches if you could i would do this mod
Old Jan 7, 2007 | 09:09 PM
Deric's Avatar
What heating eleaments did you get? Can you tell they are under the leather? I want to get this for my seats but I'm afraid you would be able to see the coil pattern bellow the leather.
-Deric
Old Jan 8, 2007 | 11:21 AM
jim010's Avatar
I don't know which heated seat pads I got, as I didn't do the install. I only did the climate module/switches.
You should not see the heated seat pads, as they are flat. Lots of after market heated seats out there, and I've never seen a problem with the upholstery.
Old Jan 17, 2007 | 05:56 PM
jim010's Avatar
For those who want to see what all the fuss is about the factory switches, I'm posting these pictures see you can see where they are.
Cheers.
Old Jan 20, 2007 | 11:33 AM
kevinb120's Avatar
Jeeze I would of just had a pro install the whole setup for under 400 and lived with the heated switch buttons on the sides of the seat base covers
Old Jan 21, 2007 | 04:00 PM
jim010's Avatar
Then that wouldn't be a stock look, now would it?
Cheers
May 3, 2026 05:42 AM
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
RCooke08GT
Feb 19, 2017 03:03 AM
