Tool For Removing Trunk Panels
Hello everyone. In a couple weeks I plan on Dynamatting the trunk, I just need the tool that is used to pop those plastic fasteners out. Any idea where I can find one other than the dealership?
Jon
Jon
Tim
got this set from summit racing. there is also a larger set. comes in very handy.
http://store.summitracing.com/partde...5&autoview=sku
On some of the plastic pins ,you can take a small screw driver and pull the inside part out,then the pin just pulls straight out. not hard at all.Look at the pin real close if it's this kind of pin,it will have a small round center( this is the part to pull out.then when replaceing them ,just put the big part of the pin in the hole,then push the center piece in to lock in place. This type of pin is the easiest to remove.lol
Evil_Capri
9/11/15 08:39 AM
