shaker1000 probs
Old Nov 3, 2007 | 05:02 PM
warlock's Avatar
shaker1000 probs
i just got my mustang and found an rca wire running from underneath the emergency brake housing area and am wondering where it plugs in or did i get hosed?
Old Nov 4, 2007 | 02:39 AM
Infinity's Avatar
Someone had a system in it before you, then just didn't pull the wiring when they put the 1000 back in. It's no big deal. What problems are you having?
Old Nov 4, 2007 | 10:29 AM
warlock's Avatar
system probs?
not having any reral probs with system other than being able to find the amps that are supposed to be with the 1000 system.was i mis-informed or do they exist?
Old Nov 4, 2007 | 03:38 PM
theedge67's Avatar
The amps on the 1000 system are enclosed with the subs in the trunk. It's all one unit. There are also amps in the driver side kick panel for the other speakers in the car (doors, door subs, rear deck speakers).
Old Nov 4, 2007 | 07:30 PM
Infinity's Avatar
Almost 100% correct. Except that the amps only power the 8" woofers in the doors, the highs (front and rear) run off internal power from the head unit.
Old Nov 4, 2007 | 08:02 PM
theedge67's Avatar
I see, good to know!
Old Nov 5, 2007 | 04:56 PM
warlock's Avatar
what i have seen in the trunk area is what looks like 2 6x9 speakers mounted up under the rear deck.__--no subs or amps in the rear or am i just blind or ****-audio?
Old Nov 5, 2007 | 04:58 PM
warlock's Avatar
also how do i remove the door panels to check and make sure its all hooked up and/or still there?..messed up a few door panels before on other vehicles and would also like a few tricks on how to remove
Old Nov 5, 2007 | 06:14 PM
Infinity's Avatar
If you have teh Shaker 1000, the subwoofers are quite obviously in a large enclosure on the right side of the trunk. The 500 has subwoofers in the doors, mounted low in the panel where the huge grill sticks out. The door woofers are in both systems. Both also include 6x8" cheap junk in the rear deck (disable these and pretend they never existed) and some enclosed 4.5" separates in a 6x8" mount high in the doors.
Old Nov 10, 2007 | 09:09 PM
ShowGT's Avatar
Any other questions?
Old Nov 11, 2007 | 08:36 AM
mustangbaxter's Avatar
Shaker 1000
it looks like this in the trunk, kinda hard to miss.
Old Nov 11, 2007 | 07:52 PM
RedDragon777's Avatar
and the amps are BEHIND the sub box not in the box
Old Nov 15, 2007 | 06:05 AM
metroplex's Avatar
From what I have heard, the Shaker 1000 subs aren't anything to write home about. I've never listened to one in person, but people that have them told me (in person, not over the Internet) that they're not going to give you that earthshattering bass where people can feel them a block away. I wonder if you can replace them with a drop-in system?
SouthernStang79
Sep 21, 2015 02:48 PM
silverbull271
Mar 9, 2008 08:48 AM
BLoG
05-09 Interior and Audio Mods
Feb 24, 2007 07:33 PM
flapjack
Oct 22, 2006 10:18 PM
flapjack
Jul 25, 2006 08:53 PM
