Shaker500 to Shaker1000 swap?
Old Feb 18, 2007 | 08:53 AM
BLoG's Avatar
Has anyone done this? What is involved? Can i still use the aux jack in my 07 with an '06 shaker1000 system?
Old Feb 19, 2007 | 07:53 AM
jcthorne's Avatar
It is a very involved retrofit. Requires significant rewiring or a change in harness. Much easier to add aftermarket amp and woofer. For all the trouble and cost, it is not worthwhile.
Old Feb 19, 2007 | 02:30 PM
BLoG's Avatar
good to know, thanks!
Old Feb 20, 2007 | 07:29 AM
another 06gt's Avatar
I bought the setup on ebay a while ago waiting for to get warm out to try it. I mounted the subs and amp tryying to figure out how to splice the harness in.
Old Feb 20, 2007 | 08:28 AM
Cheese302's Avatar
totally agree, i really like the shaker 500. for all the headaches of splicing and all i think an aftermarket trunk sub/amp would be a much better choice. I however am just sticking to the 500. To answer your actual question though. it sounds like the install is very complex, lots of running wires through the car. I beleive the shaker Head Unit from an 06 can run the aux in on the 07.
Old Feb 20, 2007 | 11:26 AM
Is there any differance between the 500 and 1000 head unit or is just silk screening. my aunt has a ford five hundread and she has the same radio but it doesn't have any silkscreening on it
Old Feb 20, 2007 | 11:30 AM
Cheese302's Avatar
honeslty i dont know, i would think that you are right and that it is the same unit, with different lettering on it.
Old Feb 21, 2007 | 07:43 AM
jcthorne's Avatar
The units are programmed differently. Some are physically different in that they are missing the connections but many are just programming. Either way, the S500 will not drive the S1000 harness/amsp/speakers. Much easier to add an aftermarket enclosure that is fit to the mustang trunk and an aftermarket amp. They are easily wired into the S500 system. Low level sound, and remote turn on signals are both present in the S500 system.
Old Feb 21, 2007 | 10:44 AM
I received part of the harness from the trunk foward. it has 2 red wires that i was going to tap the fuse box for and like you said two low level sound wires for left and right channel.
Old Feb 21, 2007 | 10:41 PM
BLoG's Avatar
can anyone recommend a slick trunk sub enclosure?
Old Feb 22, 2007 | 06:33 AM
jcthorne's Avatar
Scosche, see it at Crutchfield. Crutchfield was the only place I found that sold it without the Scosche woofer which is pretty cheap. I installed a Blaupunkt that I am very pleased with in the Scosche enclosure.
Old Feb 24, 2007 | 07:33 PM
Fryguy's Avatar
I did the MTX w/AMP from Crutchfield. Fits in the trunk perfectly and looks like it belongs there. Took about an hour or two to install (I also did Dynamat at the same time).
If you are looking for an easy install, the MTX is it. And in my opinion, sounds good with the stock Shaker 500 in the Mustang.
Ray11
Sep 25, 2015 12:43 PM
Grabber5.00
Sep 13, 2015 06:53 AM
