Shaker 500 door subs not working after radio install
Old Oct 25, 2007 | 01:44 PM
hhbh720's Avatar
Just installed my DUAL XDVD8281 on Sunday and everything works fine but the door subs. I installed everything according to the wiring diagram but might have neglected to connect the cable to the amp. Can anyone tell me where the factory amps for the Shaker 500 are located / post some pictures? Any input welcome!
Old Oct 25, 2007 | 03:33 PM
nonstopred's Avatar
I think you need some 12v-5v converter from radioshack. Not sure on the details, someon'll chime in
Old Oct 25, 2007 | 03:42 PM
krnpimpsta's Avatar
They're in the driver side footwell. They're mounted to the left-side-wall (the side towards the exterior of the car). If you stick your head under there, you should see two identical metal rectangles about 4 times as large as a pack of cigarettes or maybe a little larger than a 3.5" hard drive. (Trying to find easy reference sizes..) They're pretty hard to miss. Only two identical rectangles about that size. One for each door sub.
Old Oct 25, 2007 | 03:46 PM
dmhines's Avatar
If you used one of the adapter harnesses ... you should have used the power antenna lead or accessory lead (I forget which one) to turn on your amps. The amps are not powered by the HU ... they are merely turned on via a 5V signal from the HU ..
Old Oct 25, 2007 | 09:19 PM
hhbh720's Avatar
Thanks everybody, when I was at work, my buddy figured it out and now it works like a charm. Now just one more trip to Radioshack to get rid of that popping noise...
Old Oct 30, 2007 | 11:56 AM
fivestring45's Avatar
Hey Ben! Is the overall sound quality improved by adding this deck? Is everything else stock? What brand is it?
Thanks!
Old Oct 30, 2007 | 01:30 PM
hhbh720's Avatar
Hey Steve, it's a DUAL XDVD-8281:
http://forums.bradbarnett.net/showthread.php?t=70291
Sound is much better than stock, and I just changed the HU, kept the stock speakers and subs...
Old May 29, 2018 | 06:33 PM
musicbaff's Avatar
what was the problem? i changed mines and i cant get the subs to work . thanks
Old May 29, 2018 | 10:47 PM
m05fastbackGT's Avatar
Resurrecting a thread in which nobody has posted on in nearly 11 years? Good luck in getting a response from the person that last posted
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
dontOverSteer
Aug 11, 2015 05:28 PM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
K.A.I.N
Jul 20, 2015 06:42 AM
