Removing Cluster & center
Old Jan 10, 2007 | 02:18 PM
cruisin's Avatar
Im removing the dash cluster and the center piece with teh radio and buttons. Is there a place I could find directions for this before I go and snap some clips? Im sure its not overly difficult. I would just like to know where the clips are. I would buy a manula but they donnot have them at my dealer.
Old Jan 10, 2007 | 02:50 PM
G.T's Avatar
G.T
It's straight forward.. i'd describe it but the attached PDFs should do
1st remove the console floor, then the instrument panel center finish, then the head unit
File Type: pdf
File Type: pdf
Old Jan 10, 2007 | 03:39 PM
cruisin's Avatar
thank you very much, that makes my life a lot easier
Old Jan 10, 2007 | 04:15 PM
cruisin's Avatar
Do you have the one for the instrument cluster as well. That would help as that is coming out at the same time. (Speedo/Tach etc)
Old Jan 10, 2007 | 04:19 PM
LEO_06GT's Avatar
Here's a write-up TacoBill did which has pics showing how to remove the center console, etc.
http://forums.bradbarnett.net/showthread.php?t=58114
Old Jan 10, 2007 | 05:41 PM
RedDragon777's Avatar
he wants the guages though
Old Jan 10, 2007 | 08:23 PM
Northwest GT's Avatar
Sorry I don't have a real write up or pics, but removing the gauge cluster is really pretty simple. The whole trim piece (AC vent, speedo and tach tunnels, other AC vent) will pop loose after a little persuasion from a non-scratching pry tool (plastic). You can start on the left hand side because the seam is clearly visible there. There are four clips that hold the trim on there. Once you get that off you can see the attachment of the gauge cluster (four bolts, sorry can't remember the size). Remove them, disconnect the wiring harness and you've got the cluster out. Just be careful not to scratch the plastic gauge face as you remove it.
Old Jan 10, 2007 | 10:03 PM
cruisin's Avatar
thank you very much, ill see what ive got to pry it off and will post back with results, you guys are so helpful. I didnt realize that was just a press fit with little plastic tabs, Im on it tommorow or friday.
Old Jan 11, 2007 | 01:58 AM
G.T's Avatar
G.T
here goes
Reference to the instrument Cluster removal.
you'll need to pull/pry the finish panel gently
don't pull hard on the AC vent, or the speedo/tach cuz those could break.
good luck
File Type: pdf
File Type: pdf
Old Jan 11, 2007 | 09:34 AM
Hey thanks G.T. Those pages you posted are extremely helpful. In my description I was wrong about the right hand AC vent being part of the trim piece. But, that diagram shows it exactly.
It is pretty easy to get the gauge cluster out of there on these S197's. It was a lot more tricky to get the gauges out of my '96. Especially to get the plug connectors back in right.
Old Apr 20, 2007 | 04:49 PM
savage1969's Avatar
Thanks Louie for the info. Extremely helpfull preping for my dealer to upgrade my cluster to IUP. I wanted to remove everything except the cluster so nothing would get scratched or broken.
Old Apr 20, 2007 | 09:57 PM
OdiousBarbarian's Avatar
Louie, where did you get those PDFs from?
Would love to find a whole set of those
Old Apr 21, 2007 | 03:36 AM
G.T's Avatar
G.T
Alex, they're from the 2007-2008 service manual
i've saved the ENTIRE thing (thousands of PDFs in over 200MBs) and sent it to Brad to host it for TMS.
this was over 6 months back.. and they still haven't got the time to do so :S
Old May 9, 2007 | 10:26 AM
jayguy's Avatar
Any chance you have one for removing the center panel above the stereo? The one with the 2 vents in it?
Thanks.
Old May 23, 2007 | 06:29 PM
GottaHaveIt's Avatar
Not a Free version aggggh !
http://torrentz.ws/search/mustang-service-manual
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
