reamoving sirius stock radio
Old Sep 26, 2008 | 07:23 PM
pony power's Avatar
I know someone here has done it...I want to use the ford satellite antenna for my Starmate is there a standard plug on the back of the radio or is it wired differently then the plug and play units?
Old Sep 26, 2008 | 09:25 PM
JimC's Avatar
legacy Tms Member
You can't wire the aftermarket Sirius to work like the factory one. You can get the direct line that goes between the regular antenna and your radio so that it broadcasts directly rather that wirelessly, but you can't wire it so that the Shaker controls your Starmate.
The Ford satellite antenna that is mounted on the trunk would probably work, but I doubt that the cable is long enough to reach inside the car to where your Starmate would have to be so you can control it.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
FromZto5
Sep 30, 2015 05:28 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
samjluck
Sep 17, 2015 10:24 PM
M3hunter
Sep 10, 2015 09:26 AM
