new head unit
Old Jan 6, 2010 | 09:26 AM
hatchttu's Avatar
new head unit
Hey guys,
I have searched and searched on this topic and I am still confused. I am wanting to order a new head unit(single din alpine or pioneer) so I can use my ipod in my 06 mustang(shaker 500). I am probably going to order from crutchfield. I need to know that if I get the PAC wiring harness they charge 129 (65 with deck) for, does that take care of the door sub popping problem without having to use the voltage regulators from radio shack? And will the door subs still work. In a thread on crutchfield it says that the PAC harness has the voltage regulators built into it. I just want to use the vast knowledge base here.
I am not upgrading anything but the head unit, but I still want full functioning speakers in the door.
Old Jan 6, 2010 | 11:19 PM
ETNOATS's Avatar
Im in the same situation only with the shaker 1000. Not sure if the PAC is the way to go, or the cheaper Metra harness. Metra's usually can be found for about 15 bucks. Crutchfield says the PAC is needed for THXII systems, but I didnt think the shaker fell into that catagory.
Old Jan 24, 2010 | 07:40 PM
Rash's Avatar
bump - would like to know this as well.
Old Jan 24, 2010 | 10:58 PM
kingofsting's Avatar
dont waste your money on the PAC adapter. Ive gone through 3 or 4 single DINs and I currently have a DD Pioneer. I use an amp now (Infinity 6channel, highly recommended) but I only ever used the metra harness and volt regulator before that.
Old Jan 25, 2010 | 05:21 AM
Rash's Avatar
Does someone have a write-up on exactly how and where to attach the voltage regulator?
Old Jan 25, 2010 | 01:41 PM
gremlin190's Avatar
https://themustangsource.com/showthread.php?t=455116
Old Jan 25, 2010 | 05:44 PM
Rash's Avatar
To the OP - found this in the description of the PAC harness on Crutchfield:
Other features of the C2R-FRD1 include data bus driven retained accessory power (RAP), vehicle speed sensor (VSS) output, illumination, reverse output, parking brake output and a 5-volt regulated amp turn-on for factory installed subwoofers.
NC14GT
Sep 10, 2017 04:47 PM
OneCoolGT
Dec 10, 2015 07:55 PM
Sep 30, 2015 07:02 PM
earl610
Sep 7, 2015 11:57 AM
