Need Dead Pedal Mounting Info
Old May 1, 2008 | 03:47 PM
pegasusphototx's Avatar
Question Need Dead Pedal Mounting Info
Is it safe to screw into the area the dead pedal goes, or are there wires under there?
-danny
Old May 1, 2008 | 03:53 PM
Boltzman's Avatar
I think Taco Bill did a write up
Old May 1, 2008 | 06:33 PM
Got Oatz's Avatar
Don't know about under it, but I would certainly watch the huge wire loom to the left side......
Mike
Attached Thumbnails Need Dead Pedal Mounting Info-dead-pedal-003-large-.jpg   Need Dead Pedal Mounting Info-dead-pedal-004-large-.jpg
Old May 1, 2008 | 08:08 PM
JimC's Avatar
legacy Tms Member
The only thing under the carpet is the factory "dead pedal" which is simply a piece of styrofoam, no wires in that. What pedal are you installing though? I have the Steeda dead pedal and it mounts using a bracket that is screwed to a bolt that is just below that wire loom - nothing goes into the styrofoam (although I had to remove and trim the styrofoam to get my Steeda dead pedal in place properly)
Old May 1, 2008 | 08:09 PM
Boltzman's Avatar
i STILL can't believe how SMALL that dead pedal is
Old May 1, 2008 | 08:10 PM
I'm installing the on from Ultimate Pedals. I just screwed into the foam for now. If it loosens, I'll look into a different mounting options.
Thanks,
-danny
Old May 2, 2008 | 06:43 PM
GTMark052's Avatar
You could always stick an appropriate sized piece of wood or plastic beneath the carpet and screw into that instead of the foam.
Old May 2, 2008 | 07:16 PM
I just screwed mine in same as yours. No problems after 6 months. Hey Danny which pedal style did you go with. I went shiny with domed black rubber thingys?
Old May 2, 2008 | 10:02 PM
Mach's Avatar
Smooth Ultimate pedals here as well...with flat nubbies...I did add some longer screws for the dead pedal....
lakersfreak
Jun 13, 2022 12:29 AM
Gill5oh
Oct 6, 2017 10:50 PM
boz
Oct 1, 2015 04:47 PM
mx5jhb
Sep 30, 2015 04:44 PM
