Interior Plastic Trunk Latch Cover Broken
Old Apr 16, 2007 | 05:05 PM
mikeelia's Avatar
Has anyone come up with a fix for these? It appears mine sheared off where the "c" shaped plastic leg from the trunk lid to the surface comes together. I probably closed the trunk and something was too close to the rear and hit it.
I was thinking of making a bracket out of aluminum with a couple of bolts and nuts to attach the broken parts together. I'd toss the thing out entirely, but then I'd have to cobble together some other holder for the trunk light and the latch mechanism would then be totally exposed to anything sliding around in the trunk.
It's a pretty lightweight [one might even say cheaply made] part I think, and a friend took one look and said "what do you expect? It's a ford." That was a tough one to answer.
Mike E
Old Apr 19, 2007 | 12:00 PM
kevinb120's Avatar
Well figuring that the plastic is probably thicker then the plastic the entire Toyota FJ Looser is made out of, I wouldn't say its that cheap. Just get a new part, how much is one??
Old Apr 19, 2007 | 12:46 PM
S197 GT's Avatar
3rd Times A Charm
Epoxy....I fixed mine with it.
Old Apr 23, 2007 | 10:29 AM
05RedGT's Avatar
Mine broke as well - use epoxy - super glue will not work on this.
Old Apr 24, 2007 | 10:35 PM
mustangcr8z's Avatar
mine broke also
Took it back to my dealer, they replaced it under warranty, no problem!
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
TMDM
Sep 24, 2015 07:00 PM
