Installing a Factory NAV on a 2005 'Stang
#161
They only need to reprogram the ACM . (audio contol module) to get the radio to work. Check to see if your dealer will do this first before your purchase or else check previous posts to send it off.
#162
Any updates? I've been holding off on upgrading until the speed error has been fixed. Odd that neither Ford nor Pioneer have come up with a solution since factory installed nav units can also have the error.
#163
Update from 7/27
I talked with Kevin Friday. He said his guy was getting a 08 with factory nav. either Thurs or Friday and was going to try to pull the code from it. Hopefully it will not be too much longer. Mine works fine as long as I have a GPS signal, if i loose it, it will stop until it reaquires the sats and it will catch up. It sounds good even without the door subs. I just confirmed that they were not working. If I hear anything I will post it here.
#167
Kevin and I have been playing phone tag. I'll try him again this afternoon. He left me a message on my voice mail so I need to check in and see what's up?
The factory NAV system isn't available stock with the Shaker 1000. I'm sort of the test mule to see if it worked with the S1000, and so far it hasn't. Terrible audio quality. To be fair, it appears that the unit was programmed properly from the factory.
Hmmm... sounds like a good time to call KC for an update. It's been a few months now and I still don't have a working Shaker 1000 system.
#168
I talked with Kevin after Lunch he tried callin his tech and couldn't get him to answer. So he was going to email him. I just got an e-mail fron Kevin here it is.
"Hello,
As Per My Supplier Today New Nav Units to Ship Soon! Finally Got him on the Phone! Will reship as soon as I receive! I will Send Call Tags For Return of Defective Units! Thank You for Your Infinite Patience!
Regards,
KC"
So hopefully the problems are solved with the possible exception of the speed sensor. At leat that is the last I heard fron Kevin, but we'll see soon.
"Hello,
Regards,
KC"
#169
Is that for you and the others who bought the system to replace your S1000? I got mine off of e-bay (S500 in my car) and haven't had it reprogrammed yet because I was waiting for a fix for the speed sensor. Didn't want to have to send it out twice.
Should I just give up on the speed sensor and get it reprogrammed now?
#170
I have decided to live with it as long as my Shaker 1000 works. Hopefully the new reprogrammed unit will actually run the subs this time... (fingers crossed)
#171
nav
can we rehash the speed sensor error. i installed a 07 unit into an 06 model. my speed volume control works fine but if you check the system for errors it will show the speed error code or nav fault but everything still works flawlessly. i take it...this is the error that we are trying to eliminate.....by the way my car was originally a shaker 500 model and i too had to hunt down the correct antenna for the {am/fm} radio signal.
#172
Yes, that is the error. It happens on many 07s with factory installed NAV, not just aftermarket sales. Ford now has no intension of fixing this and is planning to issue a TSB basicly stating that it is to be considered 'normal' and causes no other difficulties. Press OK and continue....
I am ****ED. I have a defective component and Ford refuses to fix. Not the first time they have pulled this. There is a fix, the 08s do not have the problem. Likely a retrofit of all components necessary to accomplish the fix is cost prohibitive. (New powertrain control module and major portions of the main wiring harness are new for 08). Since it works fine without the speed input, one would think that Pioneer could just program a mask to ignore the error and move on. Heck, I'd be happy with that.
Shoot, release the source code and the aftermarket will take care of it.....and other things like DVD playing....
#175
I doubt Ford would change modules. There is probably some coding changes. Hopefully with the radio code only. Kevins guy is supposed to have an 08 to pull the code from so maybe everything will be fixed. The thing that is weird to me is I have an AVIC-Z1 in my 02 and the radio works fine with the speed sensor signal it puts out.
#176
The problem is on the 05 and up cars, there is no speed sensor signal at the radio. Its a data point in the data bus and the Pioneer Nav radio is having difficulty reading it for some reason on the 07s.
#177
My last conversation with Kevin centered around getting my subwoofers to work. I think we have all resigned ourselves to that error and hitting the "ok" button. I don't care anymore, I just want my Shaker 1000 to work.
#178
Just when you thought you had the best the factory could give you with a factory nav...
They also offer this...
Cheers
Voice-activated Navigation – Ford’s award-winning navigation systems get more functionality for 2008, with the DVD-based system now featuring voice activation for more convenient hands-free operation. Getting to the adventure is easier with this system, which covers the entire United States, including Alaska and Hawaii, and features a 6.5-inch color touch screen that reads and communicates directions and street names in English, Spanish and French. Voice-activated navigation is programmed with more than 100 commands. It’s available on 13 Ford, Lincoln and Mercury products for 2008.
Ford Sync™ – a voice-activated, hands-free, in-car communications and entertainment system – fully integrates mobile phones and media players into the vehicle using Bluetooth technology and USB connectivity. It seamlessly integrates the vehicle with the popular portable electronic devices of today and is upgradeable to support the devices and services of tomorrow. Unlike any other system, Sync allows users to control devices such as iPods simply by speaking to them. Developed in collaboration with Microsoft, Sync will be offered on 12 Ford, Lincoln and Mercury vehicles later this year, and on nearly all Ford, Lincoln and Mercury products within two years.
Cheers
#179
Clarification
Clarification.
I have a 2006 Mustang Convertible.
If I want Nav I have to live with:
1. U2473 speed error code.
2. Pointer going in the wrong direction
3. being 100 feet of course.
My options in purchase is to buy new or
get one out of another ford product and pay for re-programming.
Does anyone know which model ford I can get a used nav from
and have it work in my mustang without reprogramming?
I could live with the gremlins for $500-$600 but not for the cost of
a new unit.
Thank You
a new unit.
Thank You
#180
The only Problem I have with mine, other than the subs, is the speed error. My arrow points correctly and It is pretty accurate when it has a GPS Signal. The direction the arrow points depends on which mode you have the unit in. You can have it where the top of the screen is always North or where the top of the screen is the direction you are traveling. If it is set where North is the top then the Arrow will rotate depending on the direction you are traveling. Say you are heading south then the arrow will point to the bottom of the screen. In the other mode the arrow will always point to the top of the screen and the map will rotate around it.
