Infinity Kappa 682.7cf rattle?
i just installed my new Infinity Kappa 682.7cf 6x8"'s in the rear deck and pulled out the plastic anchors and put #10 nuts and bolts.. those suckers are on tight but i still have a nasty rattle now back there
this normal?? any way to fix it?? sound deadener maybe??
anyone else have this on theres? i know other have the same speakers
thanks guys
thanks guys
I had similar problems with my f-150...
I used some "great stuff" to "treat" (read glue) whatever was loose in my door and stop it from making the ****ed noise it had started making after I upgraded the speakers.
I would never recommend using great stuff for anything other than it's intended use, but I have found many.
Just have to consider clearance for windows, and to make sure your conv top isn't gonna get hung on something if you have one.
i figured as much but wanted tyo know if this is normal just for replacing the rear speakers?
im tryin to figure out what exactly is rattling?? is it the carpeting panel in the back on top of the speakers thats doing it?
robjh22
9/8/15 12:31 PM
