Help! Removing door handle trim
Old Sep 8, 2007 | 09:07 AM
ARBO's Avatar
How do I remove the trim around the door handle? I tried just working it off with a door trim tool (plastic) and I'm chicken to put much force into it. I left project with an indentation on bottom side (a liittle gap). I thought it was about to come off but, it got stubborn and I chickened out. Now I don't have a smooth fit on that underside. I want it fixed.
I saw the PDF on whole door panel removal and to me it doesn't explain how to get just this trim piece off.
I sure hope the whole pannel doesn't have to come off.
Thanks aghead of time.
Old Sep 8, 2007 | 10:20 AM
ShowGT's Avatar
Not 100% correct here, but I removed my entire door panels to remove mine.
Old Sep 8, 2007 | 11:15 AM
ARBO's Avatar
Brandon, Do you recall if it looked like something that could come off without panel removal?
I'd sure like to see more of your car, it seems you've been into about everything on it. I wish this site had a gallery for memeber pics so we could see more memeber rides.
Old Sep 8, 2007 | 01:53 PM
ARBO's Avatar
I got as far as taking out the little plate on the inside (behind handle) and removed the torx screw. Most of trim tried popping out, just not at the door handle. Is it connected from inside that requires whole pane removal? Is there a trick I don't know, or just pull like hell!! Just kidding, I ain't doing that.
Old Sep 8, 2007 | 03:39 PM
ShowGT's Avatar
When I installed my SHR billet handles, we removed the door panels so I could install Moleskin, some sound deadner and the these handles. I recall just that extra effort, not to stress anything but just that little extra and the buckets the handles mount in will snap out and away from the panel itself. You will need to either do this or unhook the cable from the handle as well.
Old Sep 8, 2007 | 04:15 PM
ARBO's Avatar
I'll take another look at it. Thanks.
RCooke08GT
Feb 19, 2017 03:03 AM
GeoWett
Sep 30, 2015 06:40 AM
Ray11
Sep 25, 2015 12:43 PM
