Help!!! Cant get Sub to Seal
Old Apr 14, 2008 | 08:13 PM
Blustang05's Avatar
Question Help!!! Cant get Sub to Seal
Hello I have Installed a set of CDT 8" Sub in to the doors of my 2005 Mustang. but the Passenger side will not seal. what Product could i use to Seal the mounting Flange. I Dont really want to use silicon because that my be a mess or a pain to remove if ever need be
thanks
Old Apr 15, 2008 | 06:05 AM
2k5GTC's Avatar
I used to use 1/4" to 5/16" foam weatherstripping tape between the box and the sub. Just be sure to pre-punch the screw holes before attempting to tighten down the sub. That stuff always worked for me. It "fills in" any extra gaps and mounting holes that exist to keep the box air-tight.
Another product you could try is the rope style caulk between the box and the sub. It does not make a mess or harden, so removal of your sub at a later time is no problem.
Old Apr 15, 2008 | 07:27 AM
Blustang05's Avatar
thanks for the reply. Iwill give it a try
Old Apr 15, 2008 | 07:56 PM
Infinity's Avatar
I use rope caulk. It's a window sealant that is kinda like grey clay, but it never dries, and can be cleaned off the surfaces easily. It also decouples the driver from the mounting surface somewhat. It comes in a box for about 4$, and it is enough to do probably 110000 speakers.
Old Apr 15, 2008 | 08:01 PM
+1 on rope caulk sealant used it on my 8's in the doors. Thought I was clever for using it, evidently I wasn't the only one.
Old Apr 17, 2008 | 08:41 AM
Infinity's Avatar
Dan Wiggins of Adire Audio suggested it to me many years ago, and I've done it for every driver I've mounted since. It works too well not to use it.
unnoticedtrails
Jul 17, 2017 11:10 AM
Airborne42
Sep 24, 2015 10:27 AM
FromZto5
Aug 24, 2015 09:02 AM
Rot Manik
1994-2004 V-8
Aug 6, 2015 05:26 PM
