Dynamatting my car..
Old Mar 25, 2008 | 12:23 PM
G.T's Avatar
G.T
i'm going all out.
already finished the trunklid and trunk area including the rear fenders.
under the rear seats and quarter panels.
today i removed the passenger seat getting ready to do the floorboards.
at this point i still have the roof, doors and floor.
it's a pain in the *** process.. and i've already gone through over 40 sq.ft of material.
my question now though, since the interior is already stripped out, now is a good time to finish this up properly once and for all.
i figured some areas might use another layer of dynamat for added insulation, but i sure as heck not gonna do the whole car over again.. it took me a week to get where i am already!
what are your thoughts on the matter?
Old Mar 25, 2008 | 12:53 PM
n8rfastback's Avatar
I say go with one layer all the way around, and then way later on if you get ambitious to go through it again and improve where you think its needed....
i started doing this to my trunk last week and i ran out of mat.. DOH!
Old Mar 25, 2008 | 01:37 PM
PenguinGT's Avatar
Typically, you want 2 coats around the wheel wells and under the seats to cut down on exhaust drone and road noise.
THat stuff is heavy though, I don't know if I'd want to add weight.
Old Mar 25, 2008 | 03:08 PM
G.T's Avatar
G.T
i've been concerned about the weight myself till i lifted a bulkpack with 32 sq.ft dynamat Xtreme..
it really wasn't all that heavy.
i figured it probably weighs less than my custom made wooden subwoofer box, which i'm planning to ditch and plant the sub in the spare wheel well
Old Mar 25, 2008 | 03:16 PM
PenguinGT's Avatar
Yeah, I've been toying with the idea of adding some eDead to mine as well just for the quieting effect. It's great for keeping exhaust noise and road noise at bay.
Old Mar 25, 2008 | 03:36 PM
G.T's Avatar
G.T
here are some pics of the current progress..
Attached Thumbnails Dynamatting my car..-res-dsc02557.jpg   Dynamatting my car..-res-dsc02558.jpg   Dynamatting my car..-res-dsc02559.jpg   Dynamatting my car..-res-dsc02553.jpg   Dynamatting my car..-res-dsc02555.jpg
Old Mar 25, 2008 | 04:18 PM
mco05gt's Avatar
Looks real nice. I did the same thing last year but I didn't do the trunk lid. I was going to take out the front seats but got scared of the side airbags. Did you run into any problems? How did you remove them without setting them off? I am hoping to finnish this project this spring.
David
Old Mar 25, 2008 | 04:26 PM
G.T's Avatar
G.T
it's really easy David.
power off the car, remove fuse #17 from the SJB panel (passenger side kick panel)
turn ignition on and you should see the airbag warning light remains on (otherwise you've removed the wrong fuse!)
switch the car back off and disconnect the battery.
wait a minute for any backup power in the system to discharge and you're good to go.
when done and the airbags are reinstalled (seats are back and connections are back in place) put the fuse back on then reconnect the battery!
it's simple as that.
for more info, refer to the following PDF.
Old Mar 25, 2008 | 04:38 PM
mco05gt's Avatar
Very cool thanks. Looks like I have a project for the weekend.
Old Mar 25, 2008 | 06:01 PM
im doing it to deaden the road noise mostly....
have you guys actually noticed a change? i dont have enough layed down to hear a difference yet
Old Mar 25, 2008 | 06:31 PM
JonCo's Avatar
Wow that looks expensive. Lol
Old Mar 25, 2008 | 06:37 PM
Infinity's Avatar
I had 300sq of eDead V1se2 and 3 gallons of liquid in my '06. I also used 100 sq of closed-cell foam, and a bunch of sponges crammed in gaps. It STILL won't kill off a good exhaust note, but it does keep out the drone.
Old Mar 25, 2008 | 07:10 PM
wow that sounds like a lot of work
Old Mar 25, 2008 | 07:16 PM
2k5GTC's Avatar
I started this same project today. I agree it is a pain to take apart the interior. One note about your trunk lid installation. You sure you want it on the surface where the weather seal hits? I am thinking that may cause a leak.
Old Mar 25, 2008 | 07:18 PM
dont put it where the seal hits.... you can trim it right around that area and it will work fine...
Old Mar 26, 2008 | 09:22 AM
PenguinGT's Avatar
eDead rocks!
We used several hundred sq feet in our '07 Tundra Crewmax (the big beast) and it made a WORLD of difference for the exhaust drone and tire drone.
SilverOne
Sep 9, 2014 06:15 AM
socal.2fast
Jun 6, 2008 07:40 AM
2k5GTC
05-09 Interior and Audio Mods
13
Apr 24, 2008 03:09 PM
Troon2004
Mar 28, 2008 08:52 PM
VVVROOM
Jan 4, 2008 08:25 AM
