CD stuck in player
Old Aug 27, 2007 | 05:56 AM
Ponycar's Avatar
CD stuck in player
Hi everyone,
I put a CD in my player this morning and now it's stuck. It won't play and, in fact, the stock 2005 player doesn't even recognize it! When I press eject, it says "NO CD." Same thing when I press CD. How can I get it out?
Any help is appreciated!
(By the way, I checked out the work instructions and did a quick search, but couldn't find the answer for this issue. Sorry if this is a re-post!)
Thanks!
Old Aug 27, 2007 | 08:52 PM
Mach's Avatar
Sounds like a warranty problem to me... If you still have the warranty, take it in and tell them the problem and let them give you a new system. I do know there has been a number of issues with cd's skipping and they normally replace the head unit. Are you sure you have not had a skipping issue also in the past?
Good Luck!
Old Aug 27, 2007 | 09:09 PM
RedDragon777's Avatar
even without warrenty, this is a recall issue on all 05-06 and some 07 Shaker 500 and 1000 systems
Old Aug 28, 2007 | 08:58 AM
Ponycar's Avatar
Thanks for your help! I'm out of warranty but will check the recalls.
Old Aug 28, 2007 | 07:40 PM
Deric's Avatar
Was this an original CD or a CDR with a label on it? If it has a label on it they (the dealer) may give you a hard time.
Old Aug 28, 2007 | 07:45 PM
shaun_beauchamp's Avatar
The wife's vert had the same issue. Dealer swapped Shaker 500 head units in about 4 hours and never an issue. Go ahead and tell them Shaun sent you...they hate me by now!
Old Aug 29, 2007 | 11:53 AM
06 Slvr Bullitt's Avatar
I haven't had this problem in my Shaker 500 but I am having this problem in my Mach 460 head unit. It seems when all 6 discs are loaded in the Mach, ejecting becomes a bit of a problem. It "sticks" in between being ejected and fully positioned in the cd magazine. Sounds like that might be the problem with your Shaker. If you happen to have another CD (or something else wide and flat) you could try sticking it into the CD player opening to jimmy the CDs. That's what I do on the Mach whenever a CD gets stuck and it works every time. Of course I bought the '03 with the Mach system used so this is just a makeshift fix until I'm able to put an aftermarket unit into it. If you're still under manufacturer's warranty, might be best to just take it to the dealership.
Old Aug 29, 2007 | 01:45 PM
Ponycar's Avatar
I'm pretty familiar with electronics and started playing around with the buttons thinking that there would be some combination that would be an "emergency eject." That didn't work, but I found some pretty cool combinations.
Anyway, after scratching my head for a while, I wondered what to do... And remembered the second rule of electronics (the first one is, of course, turn the machine on and off again) which is to hit the device. So I punched it (not too hard) squarely beneath the 12v outlet. The player recognized the CD. So I punched it again and the CD popped out!
It's fixed!!
Old Aug 30, 2007 | 05:01 AM
Mach's Avatar
...and the third rule, we all know, is to drop the problem item from approximately 6 feet to a firm (such as concrete) surface. Care should be used to not damage the firm surface while performing this step...
Old Aug 30, 2007 | 08:22 AM
Ponycar's Avatar
Exactly. Now I feel silly. Why didn't I punch it in the first place?
Old Aug 31, 2007 | 04:38 AM
Mach's Avatar
Well, you were following the steps in order.
Actually, you missed the step where you stand by the problem item, with the technical manual in hand, (so it knows you are educated in it's workings), and chant Ohm's Law at the same time.
Normally, I do this step prior to cycling power to the item. I must admit, I do not allow much time to pass before moving on to the next step though...
Old Aug 31, 2007 | 08:55 PM
2k5GTC's Avatar
I have a similar problem in my Sport Tracs 6 disc CD. The only way I can get the CDs out is to disconnect the battery for a bit, reconnect, then eject.
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
DrVet
Sep 23, 2015 01:48 PM
OneCoolGT
Off-Topic Chatter
Sep 3, 2015 07:50 AM
bigaaron
1994-2004 V-8
Aug 22, 2015 12:06 PM
07 Boss
Aug 8, 2015 11:04 AM
