Can't get the door panel off...
Old Dec 28, 2004 | 03:51 PM
Chaotic Bliss's Avatar
So I am trying to get the door panel off but I can't seem to get it. I took off the mirror controls, removed all the screws, removed all the screws for the 8" woofer but I still can't budge the door. And I can't seem to get the woofer out either. Am I missing something? Usually there are just some clips after the screws are out and the door just pops off. Can anyone provide some insight?
Old Dec 29, 2004 | 02:35 PM
Oh and I also removed the power window controls and the screw that was behind them but still no luck.
Old Dec 31, 2004 | 05:03 PM
Tiberius1701's Avatar
E-mailed instructions to you-hope they help.
Old Dec 31, 2004 | 05:05 PM
Also, woofer bolts to door panel/woofer enclosure assy-not to door sheet metal. Woofer will come off with door trim.
Old Dec 31, 2004 | 05:16 PM
Also for everybody-here are the door trim removal instructions..in pdf form.
Old Jan 2, 2005 | 02:54 PM
HOTLAP's Avatar
Ti - thanks - I was just about to ask that question!! You must have the '05 shop manual in PDF format? I'd like to purchase a copy of that if possible?
thx!
Old Jan 3, 2005 | 11:51 AM
Thank a bunch buddy! I knew there were some hidden screws I was missing.
Old Jan 3, 2005 | 06:50 PM
Zodiac's Avatar
Tiberius - awesome. Thanks a ton. Do you have one for the HU removal as well?
Old Jan 3, 2005 | 07:49 PM
OK, there are the three pdfs that detail head unit removal. This one details console finish and console removal- Note it is not required to remove entire console to remove center stack finish panel-only the top finish panel needs removal.
Old Jan 3, 2005 | 07:53 PM
Part two-center finish removal-Note: Once the center stack side trim "wings" are removed-there are openings in the sides of the dash metal frame, wiring harness removal for the climate controls and lower function panel are easily accessed here. Also-the electrical connector for the lower function panel has a pivoting latch pry it lightly with a small screwdriver to release the connector.
Old Jan 3, 2005 | 07:55 PM
Lastly-head unit removal.
Old Jan 3, 2005 | 09:46 PM
RRRoamer's Avatar
Tiberius1701,
Thanks for the info! It is appreciated.
Old Jan 5, 2005 | 12:28 PM
wbrownie's Avatar
AWESOME!!!
Thanks.
Old Apr 15, 2005 | 07:57 AM
ChrisM's Avatar
Tiberius,
Thank you!! I'm planning to replace my stock cd/radio with a Shaker 500 and these PDFs give me the DIY info I need.
Chris
Old Apr 16, 2005 | 11:41 PM
Eric's Avatar
ChrisM... do you need the Shaker? I'm through with mine now that the dealer replaced it with the series B and almost all of my McIntosh components have arrived.
RRRoamer... how goes it?
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
TMDM
Sep 24, 2015 07:00 PM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
