Boss 302 Steering Wheel Into '05 GT!
Old Feb 7, 2012 | 09:29 AM
  #61
Phorty's Avatar
just picked up a 2011 GT wheel, will be doing this install shortly, thanks!
Old Feb 11, 2012 | 07:17 PM
  #62
dgann3's Avatar
I got my wheel and interface put in, but when I try to program the buttons, nothing happens. I programmed the interface to #9 and it flashed 9 times, but after that, nothing.
Old Feb 18, 2012 | 10:54 PM
  #63
Taxman72's Avatar
I just bought this one... gonna try to pull this off too. I'll probably be hitting some of y'all up soon for an assist.
Old Feb 19, 2012 | 11:47 PM
  #64
ov3n's Avatar
Did that airbag cover come with it? I want that but can't find it.
Old Feb 19, 2012 | 11:52 PM
  #65
ov3n's Avatar
LOL Nevermind, I just found a guy on ebay that's got 25 of them...
When I looked for them a few weeks ago I didn't find any... I swear!
http://www.ebay.com/itm/FORD-MUSTANG...#ht_500wt_1074
Old Feb 20, 2012 | 06:45 PM
  #66
Taxman72's Avatar
That's where I got mine. Nice quality stuff!
Old Feb 20, 2012 | 08:20 PM
  #67
Taxman72's Avatar
Just finished the install... that airbag cover was a *****!
Old Feb 20, 2012 | 08:35 PM
  #68
ov3n's Avatar
What was wrong with it? What did you have to do?
Old Feb 20, 2012 | 08:54 PM
  #69
Taxman72's Avatar
The stock one is just really, really tight, so it's a ***** to get off and then the aftermarket one is just hard to put on. I just really had to work with it. I used a bone folder (leather working tool) to work around the airbag and get it stuffed back in there. It wasn't "hard" per se, just time consuming.
Old Feb 20, 2012 | 11:40 PM
  #70
ov3n's Avatar
could you describe the process?
Old Feb 21, 2012 | 08:33 AM
  #71
Taxman72's Avatar
First you drill out the rivets (three of them). Next you just have to work it off the airbag. It's just a hassle to get off. You'll need some kind of plastic tool like a wedge or something to work in there and work the rubber off the tabs at the back and then to help get it off the airbag. Then you just have to work the new one on. Once it's over the airbag, you have to press one side of the airbag plate down into the cover so that the long tab at the bottom can go in the slot on the cover. Then you press the other side down, pressing on the edge pressing down and towards the center to get the other side in. It's not complicated. It just takes patience. Once that's done, just use some pop rivets to resecure it and you're good to go. It's difficult getting it back in because the wiring for the new wheel is different and it gets in the way. I haven't wired mine up yet. I'm going to do it when I get my radio module to allow the wheel controls to work.
Old Apr 4, 2012 | 10:21 AM
  #72
Scruffy281's Avatar
What color Alcantara is the wheel? Black or Grey?
What color is the stitching?
Thanks!
Old Apr 5, 2012 | 11:44 AM
  #73
Taxman72's Avatar
Thanks!
Black and the stitching is just like a dull white.
Old Apr 17, 2012 | 11:53 PM
  #74
conner5255's Avatar
Got the wheel installed and the cruise is working great (2008) but now I am trying to get the audio controls working. I have the wpt 440's and an axxess and a PAC interface. Not having any luck, can anyone help? I have an AVIC X930BT head unit.
Old Apr 18, 2012 | 12:50 AM
  #75
Zaksgt's Avatar
Looks good! But not a boss wheel
Old Apr 18, 2012 | 02:20 PM
  #76
Scruffy281's Avatar
How did you wire it?
Old Apr 18, 2012 | 10:10 PM
  #77
conner5255's Avatar
Haven't wired it yet. trying to find details on what wires to connect where. I got an email from tech support at Axxes and he said that the green wire needs to be grounded, and the yellow wire to the green/white in the ASWC. I will be trying that tomorrow.
Old Apr 19, 2012 | 10:25 AM
  #78
Scruffy281's Avatar
Take a looky here: http://www.fnsweet.com/forums/showth...805#post710805
Old Apr 20, 2012 | 02:31 PM
  #79
conner5255's Avatar
Finally stopped raining enough to get out there and work! And it does! Thanks for pointing me in the right direction! And now for the spring cleaning of the car!!!
Old Apr 20, 2012 | 02:45 PM
  #80
Scruffy281's Avatar
Did you use any resistors? What wire are you using on the PWI?
