Bluetooth Mic
Here's mine. This was never suppose to be a permanent solution. After a couple hours or installing, I was just like screw it and placed it here. Said I'd come back to it. All the wires were placed away. Used zip ties to keep the wires secured underneath.
Anyhow, its actually worked just fine down there an no one can see it when in my car. So I've just left it there for going on 2 months. No problems at all. Every once in awhile the other person will have trouble but at the same time, my car isn't necessarily quiet either. But its been fine.
The other option which My son did in his Fox. Right on top of the steering column between the wheel and dash. You could actually hide it in the cluster.....
Another option. Right side of the cluster under the dash cover right were it curves down for the center dip....
I would knock that off in a matter of minutes getting in and out....
This is what I would do.
I'll take a look at the idea for around the steering column and dash.
That's a nice spot but would annoy me seeing it. Same reason I love the x2500 and having aux an USB ports on the back. No annoying wires dangling from the unit and a clean look. That's why I've been content with where I have it. Plus everyone can hear me just fine with it in that position.
Mine is routed under the dash , up the A-pillar (under the trim) and behind the head liner. If you can find it on search, I have a thread when I installed my Pioneer FH8000 with more pics with how I routed the cable:
Its a great spot, no one has problems hearing me, even with the windows down. It does get loud if I have the defroster on too high
