Anyone know anything about these speakers?
Old Jun 21, 2005 | 09:21 AM
PonyGirl's Avatar
Thumbs up
JL W6 dual 12 inch sub speakers.
They guy I bought my fiberglass box from , said these would sound great in the box, but I know NOTHING about audio.........
Each I think is 700Watts, that is all I know, I have never had JL before. I only had SONY and KENWOOD.
Also, if these are good enough, then what size Watt, brand name amp shoudl I go with?
THanks Audio Heads!!! I appreciate your help
Here are specs on the box I want to order:
Dual 12 in. Subs
Width 33.5"
Depth 16"
height 14.25"
Mounting Depth 9.5"
Hole Cutout 11.125"
Internal Airspace 2.75 cu. ft.
WILL IT FIT IN THE TRUNK?
Thanks all!! Here is what the fiberglass box looks like , but painted in screaming yellow!!!
Old Jun 21, 2005 | 09:34 AM
hawgman's Avatar
Strictly my opinion...JL Audio makes some of the best woofers on the market.
I had a pair of the Pro Comp 10" in my last car and they hit so hard you thought someone was smacking the back of the seat with a hammer.
Old Jun 21, 2005 | 09:40 AM
PonyGirl's Avatar
Should I be worried this box has no "port hole" . I know some boxes do and some dont?!?!?!?!
Old Jun 21, 2005 | 09:43 AM
hawgman's Avatar
Depends on the dynamics of the box as to whether or not it needs to be ported, the size, shape, and length of the port, the perticular speaker being used, and the wattage being pumped through it. No real cut and dry answer for that one.
Old Jun 21, 2005 | 09:47 AM
PonyGirl's Avatar
OK, the guy told me this speaker sounds good, so I might stay with that.
I might even go to dual 10's, to make sure the box will fit in the trunk. I hate to get the dual 12's , and have the box not fit in the trunk.
What amp is out there now that is mid priced and decent?
Old Jun 21, 2005 | 01:18 PM
subzero05's Avatar
You can't go wrong with JL product...Expensive stuff though
Old Jun 21, 2005 | 01:58 PM
PonyGirl's Avatar
OK, where can I go to give them the box specs, and have them tell me the best set up for the car. ?
Amp Size?
Speakers? Etc.....man, I am no good at this audio thing.
I do know I am keeping the factory head unit and speakers....just adding the dual 12's and an amp.
Anyone of you genius audio buffs whant to take me on as your project child? HELP!!!
Old Jun 21, 2005 | 02:38 PM
hawgman's Avatar
Originally posted by PonyGirl+June 21, 2005, 2:01 PM--><div class='quotetop'>QUOTE(PonyGirl @ June 21, 2005, 2:01 PM)</div><div class='quotemain'>OK, where can I go to give them the box specs, and have them tell me the best set up for the car. ?
Amp Size?
[/b]
The box manufacturer would be the best source for this information. They will know what their box is tuned to handle.
That won't last long. I would just bet that in order to make the JLs sound as they were intended, you are going to have more sub than what is going to sound good with the factory skipper and amp.
<!--QuoteBegin-PonyGirl
[/quote]
Well, I don't know if I want to take you on a my "project child" but I am sure that myself and everyone else here will do what we can to offer the best guidance for the solution you are seeking.
Old Jun 23, 2005 | 06:18 PM
RRRoamer's Avatar
The JL Audio 12W6 subs will work in the box pretty good. It is on the large end of what these speakers need for a sealed inclosure (if my memory is working), you will also loose a bit of space due to the driver itself (but not as much as a lot of people think).
The ONLY reason I would even be concerned with this is if you intend to drive them at their rated power handling. Then, you might get enough excursion to enter into the over excursion realm due to too much air space behind the sub. Of course, at that point, with the factory front speakers, ALL you will be hearing is those moster subs slamming the air around in the car.
So the short answer is don't worry about it. The JL Audio 12W6s will be GREAT speakers. Just get a great amp to drive them. Nothing will make a good speaker sound bad faster than an underrated amp that is distorting and clipping.
Old Jun 23, 2005 | 10:42 PM
wardog's Avatar
JL Audio subs rock! I've got three 12W3v2's and they hit hard. (not in the Stang)
Go to http://www.jlaudio.com/ Specs are listed for box sizes, ported and sealed. Sealed boxes will be a little smaller which is a consideration.
For amplifier power, I'd go JL Audio "Slash" series. They're not cheap, but they're not the most expensive either. If you're on a budget HiFonics seem to be a pretty good value.
I'm probably going to go with Focal mids/tweets, JL Amps and subs. Haven't decided yet whether to do two 10W7's powered with one 1000/1 or go gonzo, rip out the back seat and do two 13W7's powered with two 1000/1's.
I haven't done business with these people yet, but they seem to have some good prices. http://www.woofersetc.com/store.asp
Old Jun 24, 2005 | 01:15 PM
2Slack's Avatar
The JL's are great speakers. I would change the factory head unit. I thought just upgrading my speaker would do also, it didn't. It sounds 1000% better with the new head unit.
Old Jun 25, 2005 | 02:58 PM
ZwerRacing's Avatar
Thats a cool looking box when will you have it to show a picture of it in the trunk?
Old Jun 25, 2005 | 07:55 PM
Infinity's Avatar
Hey ZWer- are you the guy with the custom 'glass enclosures for some ED subs on either side in the trunk?
Old Jun 26, 2005 | 12:21 PM
ZwerRacing's Avatar
Nope sorry
Old Jun 26, 2005 | 03:53 PM
Zodiac's Avatar
Are they 12w6s or 12w6v2s? The w6s are a little old by a couple years on their technology, and dont hit or sound nearly as good as the v2s. I had a single 12w6v2 in my Honda Hatch and it reaaaaallly pounded. It was louded than most dual 15 setups Ive heard. The v2s are rated at 400 rms power handling, and the w6s at 300 rms. I would consider a good JL 1000/1 amp to power those.. you'll have pleanty of head room. For my single w6v2 I was sending 500 watts to it in a sealed high output wedge, never had any distortion or problems after months and months and months of play. Id say the 1000/1 would be about perfect.
I really hope that box is built really well, because you're going to be knocking it pretty hard if you ever turn these subs up to their max.
Old Jun 28, 2005 | 01:54 PM
Mellow Yellow's Avatar
Pony Girl, I have *1* JL audio 10w6v2 in a custom sealed fiberglass box mounted in the side of my trunk and it hits extremely hard, almost too hard Granted I am driving it with a 500/1 from JL audio too, but I just wanted to agree with what was said on this thread so far, you can't go wrong with JL audio, but you do want the v2's (newer version)
I can literally see my rear deck flex from the pressure created from my 10 inch, I can only imagine what 2 12's will do to your car hehe
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MartinM
Sep 19, 2015 02:11 PM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
RCooke08GT
Sep 1, 2015 08:07 PM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
