4 ga Wire into Amp Terminal - HELP
OK, I am now going crazy trying to find a Spade terminal that will go from 4 Ga wire to the Ground & Power Terminals on my Amp.
The Amp will accept spade terminals that are no more than 9MM wide. (closer to 8.5 MM)
I WANT to use either Spade Terminals or something along that line, I do NOT want to just feed the bare wire into the terminals.
Anyone know if they make such an animal and where to get it if they do?
http://www.knukonceptz.com/productDe...?prodID=ST48BK
I know for a fact these work on Kicker amps, as that's what I purchased them for. They also fit on older Alpine V12's. I haven't used them for much else, but I can promise that they're the same size as a normal 8ga spade terminal.
Sorry I don't know what size a normal 8Ga spade terminal is
Yes, they're still using the same terminals. That's the ones you need.
