Fire extinguisher mounting
Old Aug 23, 2006 | 08:28 AM
JohnP's Avatar
I need to mount a fire extinguisher in my GT vert for the open track event at Barber. This is just for the event and not a permanent mount. I don't know what they will accept but considering duct taping it to the floor. Any suggestions are welcome. Thanks.
Old Aug 23, 2006 | 10:57 AM
dbleagl21's Avatar
+1 - I Need to know the same thing.
Old Aug 23, 2006 | 06:43 PM
BeachPony's Avatar
zip ties would be better.
Old Aug 23, 2006 | 08:29 PM
Blitz's Avatar
Tried to post a pic, too big...go here http://www.blueovalforums.com/forums...ic=3556&st=500 post # 514 and go to the interior pic......the extinguisher is a permanent mount. There is a "strip" running under and behind the glove box door...sort of between the kick panel and the console. I used one of the socket screws for one hole in the bracket, drilled a self tapping screw into the strip for another. Passenger's feet fit under the extinguisher, and their legs sem OK.
Edit....and yes, the glove box door opens all the way
Old Aug 24, 2006 | 05:32 AM
98YELLOWGT's Avatar
Cool
I wrapped mine in velcro so it sticks to the carpet.
Old Aug 27, 2006 | 03:39 PM
Import-Slaya's Avatar
Not sure what the tech inspection is like at Barber, but most open track events won't even let you have loose change in your car, so a 10 pound fire extinguisher that is taped or velcroed to the floor wouldn't pass.
Ebay has a lot of different style brackets that can bolted down. That's probably the only type that will pass tech at most open track events.
Old Aug 27, 2006 | 04:39 PM
traffic142's Avatar
Shame we cannot mount one, but most of the good locations are ricer's ideas.
Old Aug 27, 2006 | 05:50 PM
karman's Avatar
That looks really good. Can you undo it easily to give the passenger more leg room when driving around town.
Old Aug 28, 2006 | 12:36 PM
Blitz's Avatar
I suppose you could pull the extinguisher and leave just the bracket, but leg room really is not a problem for most....as mentioned one's feet just go behind the extinguisher.
Old Aug 28, 2006 | 01:51 PM
AWmustang's Avatar
Do not discount a good idea simply because of it's source.
Wise words I once read.
If you want to put your extinguisher somewhere put it there. To compromise simply because someone you don't approve of did it is just plain silly.
Old Aug 28, 2006 | 07:30 PM
traffic142's Avatar
sorry , for being anti rice.....
Old Aug 30, 2006 | 01:42 PM
traffic142's Avatar
how about mounting one in your trunk area???
Old Aug 30, 2006 | 04:50 PM
karman's Avatar
Most fires happen real quick and burn wiring. If you want to take the chance of getting out, opening the trunk with your key (burnt wires),fishing out the extiguisher, then putting out the fire... go ahead.
Having one in your trunk is a good idea for day to day because you are usually putting out someone else's car, but not for the track.
Old Aug 30, 2006 | 07:31 PM
Bullitt1609's Avatar
Does anyone know the minimum required rating of the fire extinguisher in your car for the event at Barber? I believe I read a 12 BC.
Nevermind. I called and spoke with someone at Barber and was told there really isn't a minimum rating for the one in the car. Just get one around 8" - 10" tall and mount it.
Feb 10, 2017 07:12 PM
samjluck
Oct 26, 2015 05:17 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Sep 16, 2015 06:44 PM
