4 ga Wire into Amp Terminal - HELP
Old Aug 29, 2006 | 11:18 AM
OKCMustangGT's Avatar
OK, I am now going crazy trying to find a Spade terminal that will go from 4 Ga wire to the Ground & Power Terminals on my Amp.
The Amp will accept spade terminals that are no more than 9MM wide. (closer to 8.5 MM)
I WANT to use either Spade Terminals or something along that line, I do NOT want to just feed the bare wire into the terminals.
Anyone know if they make such an animal and where to get it if they do?
Old Aug 29, 2006 | 04:59 PM
Infinity's Avatar
http://www.knukonceptz.com/productDe...?prodID=ST48BK
I know for a fact these work on Kicker amps, as that's what I purchased them for. They also fit on older Alpine V12's. I haven't used them for much else, but I can promise that they're the same size as a normal 8ga spade terminal.
Old Aug 29, 2006 | 07:38 PM
Sounds like what I need. These will be going on Alpine Amps MRP-F450 & MRP-M650. So they should work on those too right ?
Sorry I don't know what size a normal 8Ga spade terminal is
Old Aug 30, 2006 | 07:34 AM
Infinity's Avatar
Yes, they're still using the same terminals. That's the ones you need.
Old Aug 30, 2006 | 08:06 AM
Can't think you enough. Just placed an order.
Mar 30, 2021 09:29 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
mx5jhb
Sep 30, 2015 04:44 PM
BigHoss
Sep 21, 2015 10:03 AM
