Windshield washer squirters
Old Jun 5, 2008 | 05:10 AM
davids2toys's Avatar
Did a search, cant find any info on how to take these out of my stock hood without cutting up the tee fitting/hose assy's...anybody got any info? I need to take these out to transfer these to my new Saleen hood...it came with NO instructions.
Old Jun 5, 2008 | 05:43 AM
adrenalin's Avatar
So you just want to remove them from the hood? From under the hood, press on the clip that is located near the front of the nozzle (closest part to the front of the hood. The piece then pushes out and forward to remove it from the hood. Pull on the tube to remove it and there you go, nozzles have been removed. If the hose is putting up a fight, warm it up with a hair dryer.
Old Jun 5, 2008 | 07:07 AM
05GT-O.C.D.'s Avatar
I lust for a M24
Mine just wiggled out w/ a little bit of push/pull. No tools needed, and definately no need to damage the hood.
I relocated mine to the wipers using the squirters from a Ford SUV - Excursion, I think. Since this pic was taken, I've tidy'd up the hose.
Old Jun 5, 2008 | 07:54 AM
watchdevil's Avatar
That's what Ford should have done with all the new Mustangs. It's hard to believe that they would put two warty eye sores on the hood when they have had the ability for decades to not choose to do so. Even the 1971-73 models had a clean hood with hidden wipers and jets.
Old Jun 5, 2008 | 08:25 AM
highvolts's Avatar
They did it so we could trick out our rides with:
Old Jun 5, 2008 | 01:21 PM
slipnotovk's Avatar
Old Jun 6, 2008 | 03:14 AM
watchdevil's Avatar
Dear God NOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!
If that was the reason Ford put them there then they certainly are not smart enough to figure out that the flat high hood would not even allow the light to point on the road...
Okay let me get this straight... washer jets that light up?... What's next? Parking lamps that shoot water up in the air like a synchronized fountain light show?
Old Jun 6, 2008 | 07:50 AM
adrenalin's Avatar
Unfortunately those do exist but they are not intended to light up the road. They are just LED's that light up to say "Look at me". I'm sure whomever installs these also got the LED exhaust tip, under car lighting, LED tire valve caps and under dash lighting.
Old Jun 6, 2008 | 08:46 AM
Thanks for the info, those hoses are on super tight and look like mini assembly's...I did not want to break them. I need to install them in the new Saleen hood
kjdavis
Jun 29, 2020 05:41 PM
yabutt
Oct 23, 2015 01:05 PM
Allen Hanback
Sep 14, 2015 04:37 PM
slufoot733
Aug 2, 2015 07:15 PM
Ghekk
'10-14 Exterior Modifications
Aug 1, 2015 12:46 PM
