Tire Width Vs. Rim Width
Old Jan 31, 2005 | 11:36 AM
viper5470's Avatar
what is the biggest width of tire you can put on the stock 17in rim in mm
Old Jan 31, 2005 | 11:37 AM
holderca1's Avatar
I think the biggest I have seen anyone do thus far on the stock rims is 255. You might be able to get more on there though.
Old Jan 31, 2005 | 11:40 AM
adrenalin's Avatar
I wouldn't go any wider than the 255
Old Jan 31, 2005 | 11:53 AM
viper5470's Avatar
so what aspect ratio is preferred 255/?/17
Old Jan 31, 2005 | 12:09 PM
holderca1's Avatar
go with 255/50/17 to keep the speedo accurate.
Old Jan 31, 2005 | 12:21 PM
viper5470's Avatar
thanks thats what i was thinkin
Old Jan 31, 2005 | 12:37 PM
pittperson's Avatar
Anyone know what happend to that fancy wheel/tire calculator that was at bigwheels (I think that was the site) that let you compare every aspect of a wheel/tire combo?
Old Jan 31, 2005 | 01:14 PM
69boss's Avatar
Try this one:
http://www.1010tires.com/tiresizecalculator.asp
Old Jan 31, 2005 | 08:27 PM
coolmac's Avatar
Check the spec page on Tire Racks site , for the tire you are considering . Tire size does vary per manufacturer.
Old Feb 1, 2005 | 09:19 AM
viper5470's Avatar
will most of the ford rims with the 4.5 bolt circle fit on the 2005 like the mach1 rims
Old Feb 1, 2005 | 09:25 AM
KansasCityTim's Avatar
They will technically fit, but the offset is all wrong. I think on the 94-04s, the offset was around + 25mm. The 05s are upwards of + 40mm (i think even 45), so they will bolt on, but they may stick out of the wells and look like crap.
Old Feb 1, 2005 | 09:49 AM
viper5470's Avatar
but the backspacing diff is half an inch
Old Feb 1, 2005 | 12:05 PM
holderca1's Avatar
Originally posted by KansasCityTim+February 1, 2005, 10:28 AM--><div class='quotetop'>QUOTE(KansasCityTim @ February 1, 2005, 10:28 AM)</div><div class='quotemain'><!--QuoteBegin-viper5470@February 1, 2005, 10:22 AM
[/b][/quote]
The Mach 1 rims fit fine, not sure about the others though.
Old Feb 3, 2005 | 01:08 AM
BarryG's Avatar
Site moved:
http://www.bigcustomwheels.com/info_specs.jsp
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
trackpack13gt
Jul 25, 2017 05:29 PM
cozyp828
Apr 18, 2016 09:46 PM
samjluck
Oct 26, 2015 05:17 PM
ricky1728
1994-2004 V-8
Sep 28, 2015 10:16 AM
