Sylvania Silver Star bulbs in 9008
Old Feb 28, 2005 | 10:47 AM
RRRoamer's Avatar
I had been intending to post this for a while. I sent an email to Sylvania customer support asking them about Silver Star bulbs in the 9008 package.
The reply I got stated that they are just now starting to work on the 9008 package for the Silver Star line and it will be towards the end of the year before it is available. She did reassure me that the stock replacement builb is available in the 9008 package...
Old Feb 28, 2005 | 10:58 AM
subzero05's Avatar
I really want the silverstar headlamp bulbs to go with my silverstar fogs..Would complete the package..Guess we'll just wait it out!
Old Feb 28, 2005 | 01:11 PM
Jibboo's Avatar
pardon my lighting ignorance ... can you guys tell me some benefits to the silverstar lights? ie: what's the difference over stock/normal lights?
thanks in advance
Old Feb 28, 2005 | 01:46 PM
adrenalin's Avatar
The difference is they are brighter and give a wider, longer lit up section at night. Problem = oncommers will flash their lights at you thinking you have your highbeams on, like I don't get that enough as it is with the GT.
Old Feb 28, 2005 | 02:24 PM
RRRoamer's Avatar
The Silver Stars are (by far) the best non HID lights out there. They are a stock replacement bulb and while they are more expensive than stock replacement bulbs, this is only in the $25-35 each range instead of the $500-$1000 a set for HID.
I had been searching high and low trying to get a set of bright, white lights on my 81 F100. I had upgraded to new bulb connectors and ran power directly off the battery with relays. That took me from 11.5V with the engine running to 13.5V or so at the bulb under load. That was a huge improvement, but still a "yellow" light. Bolting in a pair of Silver Stars got rid of the yellow and DEFINITELY made a huge improvement in overall brightness and lighting distance.
I have not been flashed since I installed them, but I also have my headlight properly adjusted. If you are getting flashed (and I don't care what your lights are as long as they are legal...), you need to get your headlights adjusted properly. The low beams should be aimed slightly towards the right side of the road so it doesn't glare oncoming cars. You can find the correct procedure or have them professionally aligned to be on the safe side.
Old Mar 2, 2005 | 12:19 PM
...'s Avatar
i could have sworn they were out, but i guess not.
I have them in my truck and they are a huge improvement...but I do get flashed all the time on 2 lane roads.
Old Mar 2, 2005 | 04:41 PM
HOTLAP's Avatar
I've installed SilverStars in the past 3 autos I've owned and they are a great "bang for the buck" mod. About 15% - 20% brighter and best of all they have a great White light - not yellow or blue - plus they are the same wattage as the stock bulbs - so no worries about overloading the system, etc.
I e-mailed the Sylvania folks in early January and at that time they said there was no SilverStar in the 9008/H13 nor were there any plans on making one......so the above news is great!
muscle car fever
Oct 29, 2015 06:53 AM
BackroadGT
V6 Performance Mods
Sep 22, 2015 07:13 PM
Fred_Garvin
Sep 17, 2015 04:10 PM
RMS70
Sep 11, 2015 07:07 PM
