Sequential Turn Signals
I have a couple videos of the sequential turn signals I put on yesterday that I got from Web Electric. Check it out:
Sequential Hazard Lights
They do appear a little fast but I prefer that over the soooo slow ones out there. They also may appear a little fast due to the blue effect the camera creates (refresh rate).
Originally posted by davids2toys@December 9, 2004, 9:14 AM
Do you have a web site for web electric...how much? easy install?
They were $179.00 with free shipping. They will also refund you $40.00 if you send your stock harness back to them because they need them to make the new sequential harnesses.
It was also very easy to install. Just pull back the cover in the trunk, remove the three nuts holding the brake light assembly, unclip the harness, remove the bulbs, put them in the new harness and put it all back together. Do the same to the other side and it's all ready to go.
There is a little more work involved if you want to stop the brake lights from having the burst effect. Once I receive my kit this week (I hope) I will document how to make those changes and were you need to connect 2 wires located under the dash.
Originally posted by BlueStangVert@December 9, 2004, 8:40 AM
Aren't they a little fast?
http://bradbarnett.net/mustangs/caro...urnsignals.mov
Originally posted by Rampant@December 9, 2004, 11:14 AM
What happens when you put the brake on? Does it flash out in sequence and then remain steady?
Originally posted by vroomvroom@December 9, 2004, 2:12 PM
are all the lights the same spped or can u make them slower and faster or is it just what u buy
Originally posted by ipitythefools@December 9, 2004, 2:26 PM
Looks good.....but does it void the warranty
