sequential tail lights
Old Dec 28, 2004 | 01:13 PM
Badsnke98's Avatar
I have the CDC set in my Cobra. One thing to keep in mind from that install is that there is a driver and passenger side difference to the harnesses. Wife wants sequential tail lights for her 05, so I will be ordering a set from some website within the next three months to have in time for summer breakout.
Old Dec 28, 2004 | 02:28 PM
adrenalin's Avatar
Go to this old thread.
http://forums.bradbarnett.net/index.php?showtopic=9133
It will tell you everything you need to know about the ones from webeproducts including on how to "disable burst brakes".
Old Dec 28, 2004 | 02:43 PM
sundeep's Avatar
Adrenalin,
I've been trying to keep up with this thread, rather that old thread, to see how the kit worked for you, and I know you were talking to Web about having future kits eliminate the 'burst' effect. Any word on if they did this, or do you still have to go through your procedure to disable the burst?
Thanks in advance!
Old Dec 29, 2004 | 06:19 PM
htwag's Avatar
Does the inner most light work as a turn signal AFTER the kit is installed (making all three lights a turn signal)? On the stock lights, the inner most light does not flash when the turn signal is turned on.
Old Dec 29, 2004 | 07:21 PM
adrenalin's Avatar
Originally posted by sundeep@December 28, 2004, 3:46 PM
Adrenalin,
Thanks in advance!
If you take a look at the thread I posted above you would have seen that I said I got the "burst brake" issue fixed so mine don't do that. The instructions are detailed as to what needs to be done.
adrenalin's Avatar
Yes, the inner most light becomes a signal light and a brake light
5pointoh
05-09 Exterior Modifications
Mar 9, 2013 04:00 PM
Full Throttle
Sep 18, 2007 07:22 AM
Cheermom97
72
Dec 29, 2005 08:05 PM
Smoov Stang Lova
Jan 6, 2005 08:22 PM
jsmth86
Aug 17, 2004 10:37 PM
