sequential tail lights
Old Dec 26, 2004 | 12:28 AM
vroomvroom's Avatar
Which sequential tail light brand is better i know cdc is coming out with them any other companies if so how much
who has the best ones?
Old Dec 27, 2004 | 08:27 AM
2bone123's Avatar
I ordered a set and am still waiting for them from web products for$179.00 I like theres because it is a whole harness that you install by unplugging the old one and plugging in the new one.
Old Dec 27, 2004 | 08:36 AM
Red Dragon 777's Avatar
that is how the CDC ones install and they have a core charger (send back the original harness and they give you back like $75 making it like a rebate)
Old Dec 27, 2004 | 08:54 AM
94tbird's Avatar
what are seqentiaL tail lights? ne1 got a pic?
Old Dec 27, 2004 | 09:07 AM
this is a 99+ but it is the same effect
Sequential Taillights
Old Dec 27, 2004 | 09:36 AM
steve19970's Avatar
Talking
Courtesy of sequentialtaillights.com (this is hazard lights, before I cause any confusion):
Courtesy of webelectricproducts.com (where I ordered mine):
Old Dec 27, 2004 | 09:52 AM
Stangfriik's Avatar
heh I wonder if they could program it where the hazards would go from one end to the other kinda like the front of Kit in Knight Rider
Lalo's Avatar
I'm people, and I like.
i gotta get me some of those when i get my stang...
my girlfriend and I saw some on a classic thunderbird, and i brought up the fact that their will be some of those for the mustang, she flipped and said i gotta get them if i get the stang
Old Dec 27, 2004 | 09:53 AM
Lalo's Avatar
i love that idea! that would look awesome lol
Old Dec 27, 2004 | 09:55 AM
the only thing i am worryed about is if they will keep flashing when you have your lights on at night or you parking lights or will they stay lit and not stop jumping
Old Dec 27, 2004 | 10:19 AM
Greywolf's Avatar
No they only flash with turn sig or emergency. On brakes they flash once then go solid.
Old Dec 27, 2004 | 10:38 AM
topconbob's Avatar
I received mine from web electric christmas eve. After reading in here where someone said they had to remove the shaker1000 speakers and run wires to the front I was a little apprehensive. That is not the case, I installed them in 30 minutes without loosening or removing the shaker. Granted 2 of the 3 nuts you can't use a socket on but it is possible with no skinned knuckles. They look great and I had someone come up to me at a gas station and said he noticed them when I turned in and wondered if they were stock.
Web Electric did a great job for $179 and you can get a $40 rebate by returning the removed harnesses.
Old Dec 27, 2004 | 01:28 PM
sync007's Avatar
Thanks Steve!!!! Just ordered mine
Old Dec 28, 2004 | 08:16 AM
Kluski's Avatar
That was Adrenelin. He removed the trunk speakers so he could remove the rear trunk panel and install the harness.
As far as running wires from the front; the original harness allowed the brake lights to "explode" on. They would blink through one series then stay solid. He wanted it to come on solid. So he ran wiring to correct this. He talked to Web Electronics and resolved this issue already.
Old Dec 28, 2004 | 08:20 AM
PonyGirl's Avatar
Can you order these through a dealer and have them install? Just wondering, I am not machanically minded. Thanks.
Moderated Post
Old Dec 28, 2004 | 08:26 AM
adrenalin's Avatar
Originally posted by Kluski+December 28, 2004, 9:19 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Kluski @ December 28, 2004, 9:19 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-topconbob@December 27, 2004, 11:41 AM
As far as running wires from the front; the original harness allowed the brake lights to "explode" on. They would blink through one series then stay solid. He wanted it to come on solid. So he ran wiring to correct this. He talked to Web Electronics and resolved this issue already. [/b][/quote]
You are right. That was me that did that. I removed the shaker 1000 because my hand is just too big to fit between the amp mounting plate and the lamp housing to remove that third bolt. Also you really didn't need to be apprehensive cause what I did only took a few more minutes than your installation.
I have had these for a few weeks now and just love em.
Old Dec 28, 2004 | 08:39 AM
Kluski's Avatar
There's not much mechanical minded about it. Unplug the old harness and plug in the new harness. If you can change a lightbulb in your living room lamp, you can change these out.
Old Dec 28, 2004 | 08:55 AM
PonyGirl's Avatar
Really?! It is that easy? WHo has the BEST deal on these right now for the 2005 models? Does it matter if you have a V6 or a V8?
Moderated Post
Old Dec 28, 2004 | 09:02 AM
holderca1's Avatar
Nope, they both have the same taillights.
Old Dec 28, 2004 | 10:32 AM
steve19970's Avatar
The only ones with them to order right now is webelectricproducts.com right now...as they said earlier, CDC is coming out with them, and they should be similarly priced-where CDC will charge more in the beginning, their rebate for the factory harnesses will be bigger too.
