Sequential Tail Lights
Old Jul 19, 2005 | 04:46 AM
Cheermom97's Avatar
To all of you that have installed the sequential tail lights in your 05. What brand did you chose and how difficult of a process was it to install them. Any suggestions or comments would be appreciated.
Old Jul 19, 2005 | 05:10 AM
Donna's Avatar
Queen Of Nascar
I have the Webelectric's plug and play version. I was able to do it myself in about an hour.
http://www.webelectricproducts.com/products.htm
Old Jul 19, 2005 | 05:17 AM
gabriel05's Avatar
I also did the Webelectric plug in and it was a piece of cake and I am not one to do much on my own. They work great.
Heres a video in the dark with the hazards on. This is they way they light up for signaling, only both at the same time
Turn Signal Video
Old Jul 19, 2005 | 05:39 AM
ponyboy66's Avatar
Very nice.
Can you change the sequence speed?
They seem a touch fast to me.
Old Jul 19, 2005 | 05:45 AM
364's Avatar
364
I put the web electric sequentials in last weekend in about 1 hour and they look great. Just follow the directions on the website. It even gives you pictures, so even if you are as inept as me when it comes to working on cars, you can still do it. They even give you a $40 refund if you send them your old wiring harness.
Old Jul 19, 2005 | 06:43 AM
adrenalin's Avatar
I have the webelectric ones. They work great. I highly recommend them. Do a search in the exterior mod section. You will find lots of info on sequentials. Some of us, myself included, have posted detailed installation instructions.
Old Jul 19, 2005 | 08:17 AM
mustangshadow's Avatar
just installed the webelectric ones last night. Took right around an hour. But I also have the shaker 1000 and have seen where a few people had problems etc. I found using ratchet wrenches made it ALOT easier to install with the shaker unit. Deffinately a great mod. The instructions are also very easy to follow.
Old Jul 19, 2005 | 08:27 AM
Jewls05GT's Avatar
I bought these:
http://cgi.ebay.com/ebaymotors/2005-Mustan...1QQcmdZViewItem
Same thing, just cheaper.
Old Jul 19, 2005 | 08:32 AM
adrenalin's Avatar
Originally posted by Jewls06GT@July 19, 2005, 8:30 AM
I bought these:
Are you sure they use the same materials? I know I doubt it.
Old Jul 19, 2005 | 08:41 AM
Idrvadodgstr8us's Avatar
theres another brand out there where you can control the speed...a guy around here does testing for aftermarket stuff on the 05....i lost the website though..they were really nice
Old Jul 19, 2005 | 09:08 AM
Blue Knight's Avatar
Do any of the kits limit sequencing to the turn signals alone? I don't want the brake lights/emer flashers to sequence.
Old Jul 19, 2005 | 09:24 AM
I am not sure But I believe there is a way to bypass the brake lights from sequencing. Do a search in the exterior mods section it may have the info there your looking for.
Old Jul 19, 2005 | 09:34 AM
Barricade's Avatar
Originally posted by adrenalin@July 19, 2005, 8:35 AM
"I bought these:
http://cgi.ebay.com/ebaymotors/2005-...QQcmdZViewItem
Same thing, just cheaper"....
I bought the same thing. I made an offer under $50 and he took it.
They are from M&M Electronics. It took me about an hour to install.
They work great. The only difference I can tell is that one is in-line
in the trunk behind the panel and the other is the harness.
There are pluses and minuses to each.
I wanted mine out of the elements and the $90-100 difference sold me.
I think web-e has a product out that is in-line for around $75ish.
From what I have seen people have been happy with both.
Old Jul 19, 2005 | 09:49 AM
hawgman's Avatar
Those are the ones I got also. Simple install took less than an hour, works great, and was under $50.
Old Jul 19, 2005 | 09:53 AM
Tres Wright's Avatar
Originally posted by Jewls06GT+July 19, 2005, 9:30 AM--><div class='quotetop'>QUOTE(Jewls06GT @ July 19, 2005, 9:30 AM)</div><div class='quotemain'>I bought these:
[/b]
That's the set I have as well. It's not a plug-and-play setup, but it's pretty quick to install nonetheless. I didn't care for how they just blobbed sealant all over the modules to damp-proof them, but they're concealed behind the trunk panels, so they can't be seen. So far I've had no trouble with them.
<!--QuoteBegin-Blue Knight
@July 19, 2005, 10:11 AM
[/quote]
There is a mod for that, but I read through it and it looked like a pain-in-the-rear. You've got to tap into some wiring under the dash and run it all the way back to the taillights. I like the stop lights sequencing though, it gets people's attention. It's much more visible than standard stop lights.
Old Jul 19, 2005 | 10:13 AM
Burke0011's Avatar
Big Falken Tires
Another vote here too for the Web Electric set - and it was a bit tight with the Shaker 1000 but definitely doable.
Old Jul 19, 2005 | 10:54 AM
adrenalin's Avatar
It is not a pain in the rear. I was the one that posted the instructions on how to do it. It takes the same amount of time to run the wires as it did to just hookup the harness on one of the taillights. Not a pain at all.
Old Jul 19, 2005 | 11:10 AM
The instructions I was referring to were off of a web site. Maybe yours are easier, but if it involves removing seats and pulling up carpet to route the wires then I will stick by the pain-in-the-rear assessment
Old Jul 19, 2005 | 11:33 AM
bpmurr's Avatar
I went with the CDC Dynamite Stick Sequentials and it took me about 45 minutes to hook it up. A very easy install.
Old Jul 19, 2005 | 11:43 AM
adrenalin's Avatar
Ya, I see what you mean. That is overkill.
