Removing Nightshades Tint?
Old Sep 17, 2009 | 08:40 AM
BlueSkyVert's Avatar
I have a stock GT grille with lights that I tried to spray with Nightshades. It looks OK, but is a bit on the purple-ly side.
I didn't sand the lenses, is there something I can use to remove the tint without making the lens appear dull?
Thanks!!
Old Sep 18, 2009 | 07:40 PM
06StangSC's Avatar
Installing the Nightshade was a nightmare for me. I got the tailights done but couldnt get the clearcoat completely smooth looking. I SUCK at the rattle can. But after I was done and put it on I realized one was darker than the other and also the clearcoat was tacky and hazy.
So I had two options, spray the good taillight darker or completely redo the **** tailight.
I did option two. To get the Nightshade/Clearcoat off I used a sanding sponge from 3M and took it all the way down with water sanding. However, once it was back to stock is was scratched to ****. Luckly with Nightshade and clearcoat reapplied the scratches arent visible at all.
So I guess I'm saying that sanding doesnt seem like a great option unless you're repainting them. Maybe paint remover from Autozone or something.
Old Sep 24, 2009 | 10:41 AM
MADSCOTSMAN's Avatar
I'm pretty sure I read somewhere that Goo-Gone will remove VHT nightshades. Not sure about if it harms the plastic though. On the thread I read it on, they were trying to get it off of their taillights, im assuming they had already sanded them at some point. You could always give it a try on some other plascit first (mayb a cheap bike reflector?), to see if it harms the plastic. GOOD LUCK
Old Sep 24, 2009 | 01:02 PM
Thanks for bumping this thread!! Since I didn't sand, I was able to completely remove the tint with just nail polish remover (acetone). The lights look just fine!
kponypower
Jun 17, 2020 07:17 AM
robjh22
'10-14 Exterior Modifications
Oct 9, 2015 02:49 PM
jim010
Sep 14, 2015 10:15 PM
earl610
Sep 7, 2015 11:57 AM
