Powdercoat mufflers?
Old Dec 24, 2008 | 08:04 PM
jmanpatsfan's Avatar
I painted the body of my mac mufflers black, but they chip and I have to repaint them about twice a year. Is it possible to just have the body of the mufflers powdercoated, leaving the tips shiny? Heat doesn't affect it because I know some people powdercoat valve covers.
Old Dec 24, 2008 | 08:51 PM
Deric's Avatar
It should be pretty easy to do since they just mask off the areas you don't want coated with a high-temp tape. Best bet is to find some local places in your area aand get quotes. If you find a place that does trailers etc they are usually pretty cheap.
Old Dec 25, 2008 | 02:22 AM
07 GT/CS's Avatar
Don't the mufflers get a lot hotter than valve covers though? I've painted my mufflers with header paint and it has stayed put for quite a while but header paint is designed for a lot hotter application.
Old Dec 25, 2008 | 09:04 AM
xtoolmaker's Avatar
They make high temp powdercoatings for mufflers and exaust pipes.Jet hot uses high temp ceramic coatings that take 1500 degree temps.Call a local shop you should be able to get it done. I did the paint so far so good.
Old Dec 27, 2008 | 04:31 PM
classix_stang289's Avatar
i dont believe anything on a car gets hotter than a manifold/header or even a catalytic converter.
exhaust pipes wont get as hot.
Sep 10, 2015 12:44 PM
earl610
Sep 6, 2015 05:48 PM
Coyote5-0
Aug 2, 2015 08:38 AM
