Please help (caliper's look rough)
Old Oct 24, 2006 | 03:55 PM
James4litre's Avatar
I just used duplicolor's caliper painting kit and it looks kinda rough, I sanded, and cleaned the calipers for a long time, and they were spotless. I put three coats on them which might have been a mistake. They look kinda bumpy and rough. Can I sand them and apply another coat? or what should I do? any advice is welcome, thanks
Old Oct 25, 2006 | 07:49 PM
cmon guys help me out any advice is helpful
Old Oct 25, 2006 | 09:04 PM
Boltzman's Avatar
The only thing i can tell you is to sand them and repaint..Otherwise see whhat a set of 4 costs new or see if someone that has new brakes wants to sell old calipers
Old Oct 25, 2006 | 09:07 PM
bob's Avatar
bob
pictures would help, but not knowing anything about the paint kit, there is the possibility that you may have to build up successive coats in order to get a nice realtively smooth paint job.
Old Oct 25, 2006 | 10:58 PM
Gearhead's Avatar
Hi,
My Duplicolor kit chipped horribly, and only in a matter of weeks! I sanded it off as best I could, and cleaned everything with Mineral Spirits. After masking, I sprayed them with Krylon's Fusion Paint, in bright red. Yes, this is the plastic paint, but it really works great on calipers, and it doesn't chip or fade. I would recommend you wear a respirator with this stuff.
Brian.
Old Oct 26, 2006 | 07:54 PM
Boltzman's Avatar
Originally Posted by Gearhead
Hi,
Brian.
How long you had it on??
Old Oct 27, 2006 | 11:44 AM
Northwest GT's Avatar
You might want to check with Eastwood www.eastwood.com . They make very good stuff and they have a brake caliper paint that should be pretty good also.
Old Oct 27, 2006 | 11:12 PM
Gearhead's Avatar
I have had the Krylon Fusion Paint on for about 6 months now. Absolutely no chipping! The stuff is only about $7 or so, and is a bargain. I have also used it on plastic, of course, and it really dries hard and tough.
Old Oct 28, 2006 | 07:43 PM
Deric's Avatar
I can also recommend the fusion (for use and needing a respirator). I used it on my Jeep flares a couple of months before trade-in amd I could bend and flex the flares without worry. I never had a chip even after getting pelted with rocks by a truck.
Old Oct 28, 2006 | 08:54 PM
rmays06's Avatar
I used duplicolor spray paint (primer, base and clear all high temp) and its been on about 5 months with no problems and it isn't bumpy either.
Old Oct 28, 2006 | 08:59 PM
Gearhead's Avatar
The Duplicolor Caliper Kit that I used was just an aerosol cleaner and a 1-part paint with a paint brush to apply.
Obviously, your primer / color / clear-coat paint system is working great and looks great.
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
Mpaps
Oct 11, 2017 08:06 PM
joemad59
Dec 30, 2015 06:13 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
lowblustang00
Sep 5, 2015 12:18 PM
