Painting Calipers - How To
Old May 1, 2006 | 02:40 PM
  #41
nole_trainer's Avatar
OK, even though I said my headliner was my "last" mod, I really want to do my calipers. I've read/searched all the post. I don't think I want to invest in 4 jack stands, but two I can buy or maybe borrow. So I will two wheels at a time. I've read to put the stand on the frame.
Now I need help. If I look under my car in the rear, is the frame right by the muffler (the 4-5" wide metal piece running down the car)? And at the front is it just behind the front tire (same beam)?? And can I use my car jack (for flat tires) to put each jack on.
Help!!
Well, I continued my search and found a few more topics. Putting my car up on all four points is starting to sound scary, huh????
Old May 1, 2006 | 03:33 PM
  #42
sanctus's Avatar
wow, yeah i thought i was a novice.. but yeah just put it on the framerails.. NOT on an axle... that will NOT be good if you do that..
Old May 2, 2006 | 09:31 AM
  #43
Went ahead and did both today, boy I made this an all day affair by jacking only two tires at a time. But I'm happy with the results. Let's see if they last....
Old May 13, 2006 | 10:06 AM
  #44
Added some white stickers....
Old May 13, 2006 | 12:06 PM
  #45
Badsnke98's Avatar
Just in case the posts or pixs are lost. I spent three and a half days spray painting all of the rear axle and wheel wells and all 4 calipers and rotors. Two jacks or stands were used as needed for the rear and one jack or block of wood under the K member. I cleaned with simple green and removed all casing lines or buildup for a smooth finish. Removed or taped anything that should not be painted. The calipers are completly painted as this car will never see wet roads. I used "Dupli-color's" Engine spray. My wife chose the color, she wanted something other than everyone else had. Once you drive, a crisp line is cut on the rotor.
Attached Thumbnails Painting Calipers - How To-p5211031-1.jpg   Painting Calipers - How To-p5211034-1.jpg   Painting Calipers - How To-p5221035-1.jpg   Painting Calipers - How To-p5231036-1.jpg   Painting Calipers - How To-p5231037-1.jpg
Old Jun 1, 2006 | 11:19 AM
  #46
slowjoe24's Avatar
Caliper Paint Drying time??
Okay Guy's..........My G2 Caliper Paint came today and I have my Xenon decals ready to paint/install! My question is approx. how long should I let the caliper paint dry before I install the wheels and drive?
HELP???
Old Jun 1, 2006 | 11:39 AM
  #47
CIVEStang's Avatar
HELP???
I painted my calipers using the kit from Eastwood. Instructions say you can remount the wheels after two hours, and to wait 24 hours before driving. The paint stays tacky for a long while, which would probably cause it to pick up dust during driving.
Old Jun 1, 2006 | 02:47 PM
  #48
slowjoe24's Avatar
Oooo good point! Thanks, I was told by a friend to wait a least 24 hours before driving! Just checking!
Thanks for the info.
May 3, 2026 05:42 AM
joemad59
Dec 30, 2015 06:13 PM
Cobiecane
Oct 23, 2015 08:44 AM
GLOCKer
Sep 28, 2015 05:20 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
