How will this fit on a GT/CS front bumper
Quick question,
I saw this on moss mustangs and thought it looked interesting. It says that it fits Shelby GT and GT/CS. How does this fit on the GT/CS front bumper? When looking at the front bumper, it just doesn't seem like this kit will fit in the lower grille. Thanks.
http://www.mossmustang.com/Shop/View...eIndexID=66441
It replaced the factory panel. There a couple here who have them.
Quick question,
unless you really want the brake cooling part, here is an eaiser and cheaper way. Just get the PIAA lights, drill a 2 1/2 hole on each side and wire them up. Will get some closer pix later.
got some plate alum from a friend and bent it to fit, drilled a hole and mounted it to the bumper extention stud behind the bumper ( you will need to go to a body shop to get the proper bolt to fit.) A wiring harness comes from PIAA, just plugs into the lights, run the wire up to the battery, and the hard part was getting the wire through the pass side firewall. taped into a switched power line, ( the blue with purple stripe, I think ) and mounted the switch infront of the parking brake. Using the switched power lead they come on when I start it and go off when I open the door. I use them as DTL right now, will probably turn them off after a while, but they look cool on.
check out this post for more info.
http://forums.bradbarnett.net/showthread.php?t=450104
it is a one off custon, but Silverhorse Racing is working on a production one that matches the upper one, due out sometime this summer.
robjh22
Custom Vanity Personalized License Plates & Brackets /Delete Brackets
14
Nov 1, 2015 11:28 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
