How to keep Fogs on with high-beams ??
Old Nov 23, 2007 | 02:31 PM
cbslade's Avatar
Does anyone know how I can re-wire so the fogs stay on with the high beams ?
Old Nov 23, 2007 | 04:27 PM
cop on my back's Avatar
Ditto on this question, I would like the same.
Please don't chime in "That is illegal in most states, you should check before you do that to you car", or "Why would you want to do that?"
I want it too, tell me how to do it, simple. Oh, and thanks in advance!
Old Nov 23, 2007 | 05:05 PM
302svt's Avatar
I would like that too. Alot of cars you could cross over the relay but I don't know about these.
Old Nov 23, 2007 | 07:51 PM
Ruphix's Avatar
Interested in this also. Subscribing
Old Nov 23, 2007 | 08:15 PM
Humboldt Stang's Avatar
Sorry, but I do have to ask:
Why do you want to do that?
Not a "Why do you want to do that, you idiot?". more like a "I'm curious why someone would want to do this, maybe it's something I'd want to do, if I knew why others did".
Old Nov 23, 2007 | 08:20 PM
codeman94's Avatar
That is illegal in most states, you should check before you do that to you car...Why would you want to do that?
Old Nov 23, 2007 | 08:27 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Isn't "to put more light on the road" the obvious answer? High beams throw the beam out far down the road but don't seem to illuminate the nearby sides of the roads as well.
Old Nov 23, 2007 | 09:40 PM
relayagent's Avatar
Old Nov 23, 2007 | 11:22 PM
302svt's Avatar
This company sells a kit.
http://www.mrtaillight.com/product_i...82bc67fd0de14b
Old Nov 24, 2007 | 12:16 AM
cbslade's Avatar
Originally Posted by 302svt
Id like to do it without another switch. In my old car I changed the wire going to the relay but didnt know if that would work and if itd cause the stangs computer to freak out.
Old Nov 24, 2007 | 07:52 AM
karman's Avatar
I changed out my fogs and put in Hella driving lights.
I rewired the headlight connectors (switching the high and low wires)
Quick and easy.
One problem...
I now have a lowbeam indicator on my dash.
I am used to this now and I always have run blue dash lights which helps.
Old Nov 24, 2007 | 04:02 PM
There is always one in every crowd...
I just found out how to do this in my 04 F150 and that is my project for the night. The Mustang is different and the same procedure won't work on it.
Old Nov 26, 2007 | 03:51 PM
302svt's Avatar
I think the only way you need the switch is if you want to turn the fogs off when on high beam.
Old Nov 26, 2007 | 05:22 PM
karman's Avatar
With mine I just push in the stock switch and they turn off.
Of course, I can't run my driving lights with my low beams but I can run just the driving lights.
Its just like stock only backwards.
It was also FREE.
Old Nov 27, 2007 | 01:35 PM
SunKing's Avatar
Here's an old thread that details the process. http://forums.bradbarnett.net/showth...t=40378&page=2
I'm thinking of trying this - and wanted to know if anyone has tried this with an '07 - and if there are any long term implications or problems.
Old Nov 28, 2007 | 04:10 PM
sodaman's Avatar
Well heres something slightly the same, was wondering if anyone has done this. I have a roush front fascia now, so now that I have two set of fogs, only one works at a time. Has anyone rewired so that both sets of fogs are on at the same time. That I would like to do, I dont need them for brights on, just both sets of fogs, the orig, and the roush. I am assuming I will probably just have to disconnect the roush kit from the factory driving lights, and rewire it so the roush switch has its own power. But if there is a cleaner way without having to add another switch for second set of fogs then I would like to keep it factory looking if possible. Thanks for any suggestions
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
DEPUTY62
Sep 12, 2015 11:12 AM
